Electric fans - Mustang Evolution
Old 03-12-2015, 12:08 PM   #1
Tyoung68's Avatar
Electric fans
Soo I just bought one for my car and I only have about a 1/4" between the fan and the water pump pulley with no shroud and the fan is right against the rad. So is there a difference between putting the fan in front of the rad vs. behind the radiator?
Old 03-12-2015, 12:34 PM   #2
BigpapaDean's Avatar
I think it's better inside and the fan as a puller. But in reality I've tried both sides and they both to the job.
BigpapaDean is offline   Reply With Quote
Old 03-12-2015, 05:22 PM   #3
ER12883's Avatar
Yeah just reverse the leads so it rotates the other direction.
ER12883 is offline   Reply With Quote
Old 03-12-2015, 05:28 PM   #4
Unless the fan blades can be reversed. Mine had that option, so it's better you make sure that your fan will work properly as a puller/pusher!!! That's an expensive mistake to make....
Old 03-12-2015, 08:55 PM   #5
Tyoung68's Avatar
Thanks guys I put it on the inside of the engine compartment for now it's pretty close to my water pump. I just attached it with those plastic zip tie looking things that push through the rad. Im going to make a shroud when I figure out how find space for it
Old 03-13-2015, 04:55 AM   #6
Ill try and find some pics of the shroud I had made last year with limited space.
Old 03-13-2015, 07:23 AM   #7
ER12883's Avatar
I started with an aluminum shroud designed for my fan and widened the hole so the fan sat inside it rather than on top of it. Gave me an extra half inch or so. Probably won't help with your space issue since you're up against the rad already, but it might give you some ideas. I also modified the core support to move the radiator forwards about a half inch as well. It was a matter of gently manipulating the sides where the mounting tabs are to move them farther forwards. Not necessarily the most elegant solution, but it certainly did the trick. Between these two, I now have almost 3/4" space from the pulley bolts to the back of the fan. Click image for larger version
Name:	ImageUploadedByMustang Evolution1426252557.094794.jpg
ID:	177293Click image for larger version
Name:	ImageUploadedByMustang Evolution1426252602.171649.jpg
ID:	177294Click image for larger version
Name:	ImageUploadedByMustang Evolution1426252645.861886.jpg
Old 03-13-2015, 05:00 PM   #8
curt68's Avatar
Cool! No pun intended, LOL! Lemme know how it works out for you, I'm thinking of doing one on mine.
curt68 is offline   Reply With Quote
Old 03-13-2015, 07:40 PM   #9
Commercial Member
matcox83's Avatar
I haven't done the electric yet but I was told you can move the fan down and to the passenger side for pulley clearance. It doesn't have to be centered.
Old 03-13-2015, 09:01 PM   #10
Tyoung68's Avatar
That's what I was thinking about doing. I thought I could make it clear but the little ties don't snug it down far enough other wise it's working like a charm. I got this one and then the little controllable thermostat easy to wire and easy to control. Only down side was how long the temp sensor wire is
Procomp Electronics PC2054S 16'' Pro-Cool Electric Fan - "S" Blade https://www.amazon.com/dp/B003U7REDG..._fp6avb0BYVKCZ
Only question is, what should the temp be at?
Old 03-14-2015, 07:48 AM   #11
Commercial Member
matcox83's Avatar
Can't give a reference, but I've always heard the 200 cid likes 180 to 190 deg thermostat if you can keep it from going much higher in traffic. Trial and error to figure out how much to run the fan. Start at on all the time and back off a little at time if you trust your gauge.
Old 03-14-2015, 09:38 AM   #12
ER12883's Avatar
Is it a probe style or threaded one? Not sure how the 6 is configured, but mine is threaded in right after the thermostat. So a temp above the thermostat is a good starting point - no need to have the fan on if the stat isn't even open.
Electric fans Meansaleen 1979-1995 Mustang GT 13 02-03-2012 12:58 PM
Electric fans? 86gt 1979-1995 Mustang GT 3 09-11-2011 12:29 PM
Do some Rangers fans have a cheek to critisise Celtic fans on 1967? twrgadarn8 Classic Mustangs 10 04-04-2010 08:54 PM
Electric Fans YEE!! HAAA!!! Mike90 1979-1995 Mustang GT 2 06-21-2009 07:41 PM
Any Final Fantasy Fans or Need For Speed Fans Justin The Bar 34 11-07-2006 11:44 AM
09:36 AM
