Need a part number research - Mustang Evolution
Old 04-06-2015, 09:43 PM   #1
RaysV6's Avatar
Send a message via Yahoo to RaysV6
rf-fise-6059-bc, I found this on the water pump, so far I think the motor I just bought today is either a 94 or 95 mustang. The 87 alternator bracket isn't matching up any. Any ideas would greatly be appreciated
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
RaysV6 is offline   Reply With Quote
Old 04-07-2015, 04:40 AM   #2
Mlarv5's Avatar
Here is some information on the water pump you have.
5.0 short water pump find
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 04-07-2015, 07:20 AM   #3
ER12883's Avatar
I've seen engine swaps where they dressed it up to look like a different year. The only real way to tell is to find the engine block casting number. On older small block Windsors, it's behind the starter motor, not sure if that holds true for later years.
ER12883 is offline   Reply With Quote
Old 04-07-2015, 07:25 AM   #4
RaysV6's Avatar
Well the trans is from a 95 gt the motor I got yesterday said it was from a 93 but has a belt ran fan. The car has an electric fan. The bracket for the alt and the tensioner doesn't line up. I'm at a lost right now spending way too much money way to quick for something I just want to run and drive.
Old 04-07-2015, 07:54 AM   #5
Mlarv5's Avatar
what year car are you working on?
what year engine are you putting in it?
I guess I am trying to figure out what is going on. You will have to find the correct brackets for the year model engine you are putting in. I am sure the JY's are full of similar models to get parts from.
Old 04-07-2015, 07:57 AM   #6
RaysV6's Avatar
I the car is an 87, the motor that was in it the rings are fried. So my buddy found supposedly a 93 5.0. But nothing from the 87 is matching up. The car has an electric fan. But there is a fan on the waterpump. The number I listed above was what was on the waterpump timing cover. So with that number I'm trying to figure out which 5.0 motors has a fan attached to the water pump. So i can find the right parts
Old 04-07-2015, 10:31 AM   #7
Mlarv5's Avatar
OK I am understanding now. That number is a Ford casting number from what I have found it comes from a 94 Mustang or a 88 to 90 something T-bird. With that said, look for a letter number combination on the block, intake or on a head. For a 90s Ford engine it should start with the letter "F" the next is a number which is the year so for a 93 engine the letter number stamping should be "F3". That will tell you more about the engine and will give you a better idea of what to do to make it fit.
Old 04-07-2015, 10:58 AM   #8
RaysV6's Avatar
Awesome thanx bro, to eliviate alot of the bs, I think we are just gunna swap from the 87 over brackets and all
Need a part number for this interior part kingstrider 2011-2014 Mustang GT 10 12-29-2014 10:30 PM
Need a part number sbbamafan Mustang DIY and Technical 2 12-16-2014 08:52 AM
PBR Dual-Piston Caliper Part Number? Cope Pre-2005 V6 Mustang 6 11-24-2009 10:57 AM
Reservoir part number cterie 1996-2004 Mustang GT 1 09-02-2006 05:23 PM
your favorite number attempt number 2 wiarumas The Bar 18 12-04-2005 11:18 PM
02:27 PM
