Window regulator help? - Mustang Evolution
Old 04-21-2015, 09:21 PM   #1
Michaelgranlund's Avatar
Hey all, just wondering if I could get some advice here. Replacing the regulator on my 69 Grandé and this happened Click image for larger version
Name:	ImageUploadedByMustang Evolution1429672843.777525.jpg
As you can tell, the alignment is way off. Anyone know a way to fix this without having to start over? I've tried wiggling and loosening bolts and arms but I'm out of ideas aside from starting over. Thanks guys!
Michaelgranlund is offline   Reply With Quote
Old 05-02-2015, 08:11 PM   #2
Commercial Member
matcox83's Avatar
Did you get it figured out? I feel bad there were no responses but I'm not familiar with the '69 setup. Window adjustment scares away a lot of people too. It really is trial and error. If you don't know which adjustments do what, you'll need a manual.
Sent from my SM-T700 using Mustang Evolution mobile app
Old 05-03-2015, 04:41 AM   #3
Tyoung68's Avatar
Pretty much only way is to start over. When I tried to do mine I I just tightened everything all the way and adjusted from there. Took me many months and many skinned knuckles to get everything weather tight
Old 09-05-2015, 02:39 AM   #4
I did find out what went wrong! There was a random hole which I screwed it all into but it just took a good look to figure out what went wrong! Thanks you guys.
Old 09-06-2015, 07:45 AM   #5
Commercial Member
matcox83's Avatar
Persistence pays off in the end!
Window Regulator Motor issue Shelton 1979-1995 Mustang GT 2 08-28-2013 10:21 PM
Wanted: 03 V6 drivers side window regulator JeremyMc77 Mustang Parts for Sale and Wanted 0 04-10-2013 10:29 PM
Window Issues - Motor or Regulator StreetJMusic Pre-2005 V6 Mustang 2 08-21-2011 12:38 PM
I need a reproduction window regulator scissor assembly for a 1967 mustang coupe.? trystan General Mustang Discussion 2 08-25-2009 04:21 AM
05:41 AM
