73 mach 1 project. - Mustang Evolution
Old 05-19-2015, 07:21 PM   #1
73 mach 1 project.
Hi everyone. First time poster, long time viewer. I am completely restoring a 73 Mach 1 with a GT package from a 2010 mustang GT. Went with rear coil suspension and wide drag slicks. Car is just a racer. Twin turbo'd 302 with bored pistons, stroker kit and upgraded camshaft and aluminum edelbrock heads. Need ideas to push out more power. I do have 4.11 gearing in a 9" ford rear end. Any ideas will help. I know I'm probably forgetting a lot that I did to it but I'll remember later.
stangcustom is offline   Reply With Quote
Old 05-19-2015, 07:23 PM   #2
Oh and I put 96lb injectors in it.
Old 05-19-2015, 07:23 PM   #3
How much power is it putting out now?
Adventure till you drop
Recon is online now   Reply With Quote
Old 05-19-2015, 07:24 PM   #4
natestang07's Avatar
Are you doing a restomod? I'm confused
Old 05-21-2015, 12:14 AM   #5
Yes I am doing a restomod and I was going to put in a modded out 302 but I'm thinking about putting in a 460 and doing everything to it that I did to the 302. Any thoughts?? Still need advice on what to do to get more horsepower out of it. The 302 was pushing out 575 HP and 560 ft lbs of torque.... But that's what the 460 does stock..... So idk what I'll be getting out of it.
Old 05-24-2015, 04:22 PM   #6
Update. I am pushing out 745hp and 652 ft lbs of torque with the 460 stroker twin turbocharged.
Old 05-24-2015, 04:24 PM   #7
73 mach 1 project.
Good God, that's strong. Is that RWHP? And how much boost? Are carbed or fuel injected?
Old 05-24-2015, 05:12 PM   #8
It is dual carburated with dual fuel injectors. Same set up as a 91' camaro 350, but built with ford parts. Ram air, and twin cold air intakes. I am getting 205hp from the turbos. And an additional 30hp from the ram air and intakes. The 460 is stroked out to be a 502 with an upgraded racing camshaft. 4.11:1 rear gearing and yes that is 745 rwhp. The torque isn't exact (I used an online torque calculator but it should be close). Edelbrock carbs, holley intake manifold and heads. Ford racing aluminum valve covers. And the 460 motor was originally out of a 77 ford truck, so it is still original to the 70's like my mach 1 is.... Just with a lot of performance upgrades. I do need some advice on interior.
Old 05-24-2015, 05:19 PM   #9
As I said in my first posting, the mach 1 has a GT package from a 2010 mustang gt. It was my dads old car, he just upgraded to the 2015 and let me use the '10 for parts upgrades. So I took everything that made it a GT and put it in the 73. Had to modify a lot but it surprisingly fit in really close. Just some clearance issues. Heavy duty rear sway bar, the whole nine yards. Power steering and the braking system from a 97 f350 power stroke with the 7.3. Again, this mustang is far from being completed and need ideas for the interior. I do NOT want back seats though. And the car is white with black accents.
Old 05-24-2015, 05:40 PM   #10
Maybe get some Recaro racing seats for it. Do you plan on putting a roll cage in it?
Old 05-24-2015, 05:42 PM   #11
fomoco4life's Avatar
This car sounds awesome, what is ur exhaust setup?are u running tuned headers? Think I saw aftermarket rear seat delete somewhere, I'll have to look. We need pics or it isn't real, lol.
Old 05-24-2015, 08:54 PM   #12
I am putting in a custom roll cage underneath the interior trim. I did a custom 'header back' exhaust. The car has 4, 3" pipes that come out two on each side of the car. One in front on the back tire and one just behind the back tire. That is on both sides. My exhaust manifolds are custom built to allow the turbos to breathe better and for the pure power of the 460. I was able to fabricate them pretty easily in my garage. And I am not posting any pictures of the car until its done. I will post pictures of my sketch-ups for the layout of things when I can get to a computer.
Old 05-24-2015, 08:57 PM   #13
I was actually thinking about getting racing seats for it. The 2015 NPD catalog has some pretty nice racing seats and I also found a few online. But both sets are $1000+ for just the two front seats and that's exactly in my budget at the moment. Anyone have any places where to get two racing feats for relatively cheap? I only need the front two seats.
Old 05-24-2015, 09:00 PM   #14
The twin cold air intakes are piped directly to the intake on the turbos. And I am using a 06' Cummins intercooler for the turbos.
Old 05-24-2015, 09:09 PM   #15
Sounds like a very impressive piece. I'd love to see some pictures of it.
Old 05-24-2015, 11:03 PM   #16
BA68 mustang's Avatar
Summit racing sells kirkey drag seats for around 150 a pop
Smoke tires not drugs
BA68 mustang is offline   Reply With Quote
Old 05-25-2015, 09:56 AM   #17
As I said, I'm not posting any actual pictures of the car until its done, but I will post pictures of my sketchups for how I wanted things to lay out. And I will definitally look into those seats, thanks. I don't know much about how to do any more weight reduction in the car. It is currently at 2958 lbs and my target it 2500-2700. Any ideas.
Old 05-25-2015, 10:22 AM   #18
73 mach 1 project.
I'd say look into getting fiberglass/aluminum body pieces and bumpers. Unless you've already done so. Same goes for aluminum heads. But probably not to much more you can do. Just things here and there.
Old 05-25-2015, 11:03 AM   #19
That seems pretty light for all that power
Old 05-25-2015, 11:06 AM   #20
If the block was aluminum then you'd probably be at your desired weight. But you might need to do a few other things.
Old 05-25-2015, 06:39 PM   #21
I'd say start with stripping out all the unneeded parts from the interior, trim panels, sound deadening and scrape off all of the undercoating, a few pounds here band there adds up
Old 05-25-2015, 07:57 PM   #22
ER12883's Avatar
This. Having recently stripped my interior, I can say all the deadening, carpet, hardware, etc adds up. Also as mentioned see about fiberglass fenders and hood, that should save you a lot more weight. How much of a racer are you making? If you want to get crazy, see what the regulations are for rear window and door glass.
ER12883 is offline   Reply With Quote
Old 05-26-2015, 09:38 AM   #23
DaddyO's Avatar
I'm calling BS on this one. I worked for a few years on mine and put up photos all along the way. Was glad to get each job accomplished and happy to show off my hard work each time I got closer to being able to drive it again. But not 1 photo until it's finished. Right....waddaya think Dean?
DaddyO is offline   Reply With Quote
Old 05-26-2015, 08:07 PM   #24
ER12883's Avatar
I have my doubts too, but I'll play along...
Old 05-26-2015, 08:12 PM   #25
73 mach 1 project.
To be honest I've never met someone who didn't want to share their car's restoration. I mean us classic car enthusiasts live for that stuff. We love seeing old abandon cars, turned into gems. I personally love seeing every tiny little detail of the progress in the restoration. That's just me.
I mean I'm posting about my Challenger's restoration on my thread, on this mustang forum. I didn't expect it to get as much attention as it's getting. It looks like crap at the moment, but it's something that you look back on. And say my car looked like that at one time now it's absolutely beautiful.
Old 05-26-2015, 09:57 PM   #26
03Graymach's Avatar
I called bs as soon as he said he was think about changing the motor and having it fully switched out the motor and all the mods on it in 3 days I have never seen a shop work that fast and to get the hp he had to have put it on a dyno and that would give tq too
03Graymach is offline   Reply With Quote
Old 05-26-2015, 10:07 PM   #27
73 mach 1 project.
See I have no problem posting this...
Name:	ImageUploadedByMustang Evolution1432699454.647330.jpg
Name:	ImageUploadedByMustang Evolution1432699473.732207.jpg
Yea, it looks bad, but in time it will be beautiful. And it's not even going to be painted yellow.
Just give us something to see, because they're right. For all we know this car you are talking about doesn't exist. We've seen no proof, and with the power figures that you're claiming, it's just hard to believe with out seeing it. It's definitely possible for a hopped up boost 460 stroker, but show us something.
Old 05-26-2015, 10:18 PM   #28
ER12883's Avatar
I'll see your shell and raise you a skylight Click image for larger version
Name:	ImageUploadedByMustang Evolution1432700301.776952.jpg
Old 05-26-2015, 10:23 PM   #29
73 mach 1 project.
Now it's a shell. It looked like that, but most of the body work is done. All the replacement body pieces I needed are either on or waiting to be put on the car. Plus I did a lot of engine work and did an auto to manual swap.
Name:	ImageUploadedByMustang Evolution1432700551.986032.jpg
And she's going to look like that.
Made an offer on a 64 GTO and I'm looking for an AMC. I love doing restorations, it's my calling.
Old 05-26-2015, 10:45 PM   #30
Damn guys, that stuff is so cool.
Old 05-27-2015, 05:34 AM   #31
DaddyO's Avatar
Yep...nice....that's what I'm talkin about. My 66GT coup stores boxes for current project. 19' tunnel hull drag boat. Off the streets and on the creeks. Click image for larger version
Name:	ImageUploadedByMustang Evolution1432726401.707558.jpg
ID:	183474Click image for larger version
Name:	ImageUploadedByMustang Evolution1432726438.008510.jpg
ID:	183475Click image for larger version
Name:	ImageUploadedByMustang Evolution1432726467.354275.jpg
Old 05-27-2015, 01:32 PM   #32
Took a few screenshots of the 73 from my Facebook when I first bought it just to satisfy you guys. I'm not one to fall into peer pressure but its only to get you all to shut up about it "not being real"
Sent from my XT907 using Mustang Evolution mobile app
Old 05-27-2015, 01:33 PM   #33
More pics to come but that's all you guys are getting for now.
ID:	183504   Click image for larger version
Old 05-27-2015, 01:35 PM   #34
I really can't afford the fiberglass body panels and I still want the car to look stock on the inside and out. (Kind of) I still want it to be street legal and have all the interior trim.
Old 05-27-2015, 01:46 PM   #35
In that case your not going to get too much lighter than you are right now. Fiberglass body pieces and interior strip, you'd be there no doubt. Which it's already very light for a boosted 460 stroker. Now pictures of this engine would be nice.
Hurst Mach 1 Project nelly012 1996-2004 Mustang GT 9 12-30-2014 01:54 PM
PRAYING for this Mach 1 project Scream 1996-2004 Mustang GT 20 07-21-2013 10:49 PM
For Sale: 1970 Mach 1 project FortyBrandon Mustangs for Sale and Wanted 3 05-23-2013 02:08 AM
Mach 1 Tangerine! :: 2004 Ford Mustang Mach 1 Nel86 Member Garages 3 06-16-2011 02:21 PM
First restoration Project HELP! 77 Mustang II Mach 1 muffler opinion and bumper? gail General Mustang Discussion 2 03-07-2010 08:30 AM
06:23 PM
