Classic mustang schooling - Mustang Evolution
Old 05-25-2015, 10:43 AM   #1
Whitelightning's Avatar
Hey there, I'm very new to classic fords and I've managed to pick up 3 mustangs over the weekend. A 1966 289 car, no drivetrain. A 1967 white mustang with a i6 automatic. And a 1968 mustang i6 automatic.
What would be required to swap the sixxer cars to the 5 lug? Will the 66 rear end axles fit under it?
What are the general specs of these? Here is the 66Click image for larger version
Name:	ImageUploadedByMustang Evolution1432572226.279968.jpg
Old 05-25-2015, 10:52 AM   #2
Normally, the conversion is available through companies like year one. But those cars are not very stout. The 289 might be pushing 270ish if that is the Hi-Po. The 6 bangers HP is in the 100s.
Edit: reread your post, thought you had the 289.
Adventure till you drop
Old 05-27-2015, 01:38 AM   #3
Tyoung68's Avatar
Are you swapping out a 6 for an 8?
And which one are you talking about swapping to a 5 lug?
I have a 68 and I swapped it to 5 lug by
8in rear end
All new bushings
Ball joints
Shocks
And a stock i6 DS with fit length wise to a 8in with a c4 just can't remember what I did about the u joints. But it want hard
And then, springs if you change to an v8
And if you are planing on a v8 then the most important is brakes.
I got a power booster/dual master. And new brake lines.
And If you are redoing all the suspension then look into a Shelby drop which moves the upper control arm down for better suspension geometry during cornering.
Old 05-27-2015, 11:05 AM   #4
Cooolbreeez's Avatar
Congrats on the cars! Must have got a great deal to pick up 3. Do the 67 & 68 run?
Cooolbreeez is offline   Reply With Quote
Old 05-28-2015, 08:33 PM   #5
66strate6's Avatar
I'm interested in doing a v8 swap on my 66 as well. I am planning on getting an 8" rear axle but right before I got the car there was 2500 worth of suspension done so I was hoping to do as little suspension work as possible. What do u plan on doing to your steering? I heard you are supposed to get v8 spindles and linkage but what is a MUST and what is suggested? Keep me updated on what you decide to do
66strate6 is offline   Reply With Quote
Old 05-28-2015, 10:34 PM   #6
Tyoung68's Avatar
For 68 you can keep the spindles from the 6's well at least for a wildwood disk brake kit
Old 05-29-2015, 01:51 PM   #7
I'm not sure but it's probably a mustang 2 setup. Planning a mod motor swap.
Old 05-29-2015, 01:52 PM   #8
They both do. The 67 idles rough but that's a carb tuning issue. The 68 has a small problem starting but runs great.
These cars come with a c4 automatic right?
Old 05-29-2015, 02:45 PM   #9
My 67 289 has a c4 auto trans, I'm assuming yours would as well.
Old 05-29-2015, 08:07 PM   #10
ER12883's Avatar
My 67 289 HAD a C4 (and HAD a 289 too).
ER12883 is offline   Reply With Quote
What do you think is better looking, a classic cougar or a classic Mustang? brewer Classic Mustangs 20 04-11-2010 01:27 AM
What is the best car alarm for my classic mustang. It is a 1965 Mustang Coupe.? derrold Classic Mustangs 3 08-23-2009 03:03 PM
Is the 1967 Mustang the best looking classic Mustang? cibor Classic Mustangs 6 08-21-2009 12:22 PM
How-to: Swapping a late model, EFI 5.0 and a t-5 into your classic Mustang fast64 1979-1995 Mustang GT 8 05-29-2005 04:15 PM
Bullit Intake - Schooling Needed bluemustang 1996-2004 Mustang GT 4 02-13-2004 06:28 PM
02:12 PM
