9 inch rear end - Mustang Evolution
Old 06-08-2015, 09:11 AM   #1
Aggiesrok's Avatar
9 inch rear end
I've got a 67 with a 289 and a stock 8" rear end 2.80 gears.
The motor is probably in the low 300HP range.
I have a 9" rear housing. The question is:
Should I build it as a small 9" and use my existing 28 spline axles and brakes? or Should I build the standard 9" with the 31 spline axles?
I am trying to keep the costs down and I don't plan on any dramatic HP increases anytime soon.
Old 06-08-2015, 12:18 PM   #2
fstbck70's Avatar
Region: Nebraska
The axles will be the weak point with whichever setup you go with. But you'll have to spend quite a bit more or search junkyards longer to upgrade.
fstbck70 is offline   Reply With Quote
Old 06-08-2015, 12:40 PM   #3
Aggiesrok's Avatar
You mean searching for 31 splines?
How much HP do you think a locking 28 spline axle can handle?
Old 06-08-2015, 01:24 PM   #4
fstbck70's Avatar
Region: Nebraska
No I mean the 28 spline axles are going to be the weakest part of the 9 inch rear end. I'd upgrade to 31 spline and not worry about it, but that is just me.
I'd say the 28's would be good for around 300-350 hp, but it's not so much the hp that will break them, but a combination of hp, torque, and traction. You may be completely fine with 28's, it just really depends on the application.
Old 06-08-2015, 02:33 PM   #5
Aggiesrok's Avatar
I knew going 31 is the way to go, I guess I was just trying to save some cash. But I it's better to go ahead with 31 and have it take a little longer and not have to worry about it. Thanks.
Do you know if the drum brakes are the same for 31?
Old 07-31-2015, 08:39 AM   #6
olerodder's Avatar
Region: Oregon
This thread is over a month old...............don't know what you've done but it all comes down the what's in the pumpkin...............if you have a locker or posi then I'd go with the 31 spline...................if you don't have either...........I'd stick with the 28 spline..........it's torque that will break the axle, not HP.
My Maverick turned 9.80's in the quarter with 544 lbft of torque with a 9" with 31 spline axles..............the motor had 644hp and the rear end was originally put in the car in 1979 to compete in the 79 Winternationals.
9" Fords are hard to beat...............unless you are using a Dana60.
Drum brakes are the same...................
Old 07-31-2015, 10:15 AM   #7
Aggiesrok's Avatar
Thanks
I went 31, I've got the housing, axles and case cover. I need the center section and I'm going posi. My last issue is gears. It's a DD, so nothing crazy. Im thinking 3:25. I'd like to go 3:55, but it's a C4, so no OD.
Chevy runs deep, don't step in Chevy.
Old 07-31-2015, 11:19 AM   #8
olerodder's Avatar
Region: Oregon
Thanks
Ok, just a couple of questions then.
Are you commuting mostly on freeways or city roads.
What size tires and wheels are on the car.
What have you done to the motor?, cam, headers, heads, intake, carb and ignition.
I'll tell you from experience that 3.55's will be a lot more fun to drive than 3.25's. I put 3.55's in my 66GT with a mod'd C4, nothing drastic..........just a nice street C4. The motor was an original 289 HiPo with headers and made 366HP at the crank.....different carb and heads.
Or, you could use the 3.25's and put a stall converter in the car..........nothing drastic..........which would wake it up off the line.........a lot!
Old 08-01-2015, 12:10 AM   #9
Aggiesrok's Avatar
It's mostly city, but with some highways (it's Texas).
225/50/17
The engine is a 289 block, 302 heads, roller tip rockers, mild cam, 4bbl 600cfm carb, edelbrock alum. performer, tri Y headers. I've only had the car about 2 years and haven't been in the engine to know the exact cam. Had the heads out to drill and tap for screw in studs and replaced the intake and rebuilt the carb.
I had 3.55 on my 07, they were great.
8 inch rear end rebuild 66strate6 Classic Mustangs 6 05-27-2015 08:15 AM
9 inch rear end swap Foxresto 1979-1995 Mustang GT 8 02-26-2014 07:16 AM
15 inch or 17 inch rims Vistablue Mustang Wheels & Tires 21 01-11-2013 05:15 AM
3.5 inch or 4 inch tips? 2002Gt 1996-2004 Mustang GT 73 06-19-2011 09:29 PM
3.73 gears for 7.5 inch rear end saleen0027 Mustang Parts for Sale and Wanted 21 07-06-2005 09:04 AM
09:06 PM
