Need some tips for my motor swap - Mustang Evolution
Old 07-11-2015, 07:48 PM   #1
I have an 82 mustang GL and I am putting a 302 that I got from a 1990 mustang GT and I was wondering could I use the same gas tank? I know since my car has a carb and the fuel pump isn't in the tank and the motor that's going in is fuel injected I would need to put a pump in the tank I'm assuming. Any tips on this and the whole 5.0 conversion would really help. Thanks
BDMmotors12 is offline   Reply With Quote
Old 07-11-2015, 08:39 PM   #2
Put on a frame mounted fuel pump,problem solved.change wiring harness and pcm from donor car you get motor from
ALLYDRIVER1 is offline   Reply With Quote
Old 07-11-2015, 09:33 PM   #3
I got the complete harness / computer from the donor already. Does the fuel lines need to be changed for any reason? I'm new to this I'm 21 years old and just starting my career in this field so any info you can give me would be appreciated
Old 07-12-2015, 12:12 AM   #4
Tyoung68's Avatar
Any rubber hoses will. Carb hose won't last with that high of pressure
Old 07-12-2015, 12:47 AM   #5
Tyoung68's Avatar
Old 07-12-2015, 09:38 AM   #6
ER12883's Avatar
Yep, make sure you get hose designed for fuel injected because it's a higher pressure. Also you might need a return line going back to the take (someone check me on that one - I'm not sure if that's all EFI cars).
ER12883 is offline   Reply With Quote
Old 07-12-2015, 01:00 PM   #7
Thanks everyone I appreciate the help
blown 99 gt motor puting in a 2000 gt motor derrickk 1996-2004 Mustang GT 9 07-12-2015 12:05 PM
2001 V6 to V8 swap need tips any info will help Bigmike2008 2005-2010 Mustang GT 0 05-28-2014 04:27 PM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
SLP Tips and stock tips from 98 Cobra SVT_Rob Mustang Parts for Sale and Wanted 7 08-10-2004 09:08 PM
10:37 AM
