68 parking lights rebuild - Mustang Evolution
Old 07-19-2015, 09:34 PM   #1
Tyoung68's Avatar
Well my lights quit working and I didn't feel like spending 60$ on new ones so I tried to re build them and well for 6$ I fixed them. I will say that if you have stock wiring and the lenses are crappy then it's probably be worth it to just buy new ones.
Anyways I just picked up two light plugs from autozone. I forget to take a picture of them but the are plugs for 1197 bulbs ( the ones on the left) Click image for larger version
Name:	ImageUploadedByMustang Evolution1437362490.374060.jpg
So first you will need to cut off the old part where the bulb went
Name:	ImageUploadedByMustang Evolution1437362613.028722.jpg
Then you will need to cut a a cross into the remaining part on the housing and then just use a screw driver to pry the pieces off.
Name:	ImageUploadedByMustang Evolution1437362703.335572.jpg
Next you will need to get the inner ring off. I used a sanding wheel on the end of a Dremel I just went around in a circle till the ring started spinning then pried it out with a screw driver.
Name:	ImageUploadedByMustang Evolution1437362841.542335.jpg
After that it's time to rebuild it. I just took a wire brush to it and cleaned it up a bit because it will need to be grounded. I just got a wire and where the housing it self bolts on I just ran a wire from the stud to the body. Then put the new light bulb socket in and bend the little tabes over and put in the bulbs. And your done! This job literally took less time to do than writing this so well worth it. I will say that the bulbs don't fit as well into the sockets. I had to file down the bulb a bit on the little nubs the hold it in and the solder joint where the ground the bulb but after that it fits like a glove. So here's the final product.
Name:	ImageUploadedByMustang Evolution1437363083.678741.jpg
Old 07-19-2015, 10:34 PM   #2
ER12883's Avatar
Nice. So did you essentially turn the old setup into a housing for a modern bulb?
I haven't done anything with mine other than take them off, so I'm not really familiar with these pieces yet.
ER12883 is offline   Reply With Quote
Old 07-19-2015, 10:44 PM   #3
Tyoung68's Avatar
No, on mine the springs rusted so there wasn't any pressure on the contacts so the lights wouldn't come on if that makes sense? The bulbs are the same as before just now they work lol
Old 07-19-2015, 11:06 PM   #4
Nicely done!
Parking lights and dash lights not working Liltj76 1996-2004 Mustang GT 3 12-08-2013 07:10 PM
Parking lot parking FortyBrandon The Bar 2 07-14-2013 04:33 PM
rebuild of a recent rebuild Black99Snake SVT Mustang 12 08-20-2011 05:24 PM
Lexus' Self-Parking car........Not so self parking! Thomas91169 Pictures and Videos 31 12-04-2006 12:17 AM
donor rebuild vs current engine rebuild cash05_mustang Pre-2005 V6 Mustang 2 07-01-2006 01:09 PM
» Members Mustangs
98 V6
bmabbott
50th
Bill50th
Add your Mustang
06:55 AM
