73 mustang convt. engine code - Mustang Evolution
Old 12-05-2015, 07:25 PM   #1
Title says h code engine. Engine is a q code Did mustang put q codes in some of these and not change the vin numbers ?
Confused
Halltmja is offline   Reply With Quote
Old 12-05-2015, 07:31 PM   #2
Name:	ImageUploadedByMustang Evolution1449369047.901736.jpg
73 mustang engine codes.
Pick your poison.
Old 12-05-2015, 07:41 PM   #3
I am starting to wonder if someone swapped the engines out
Old 12-05-2015, 07:56 PM   #4
Most likely; 42 years is a long time.
Pick your poison.
Old 12-06-2015, 01:02 PM   #5
Ok. Looked at the engine . It is a 72 Stamped on tg e left back under the head is 2F 237683. Anyone know if this is a q code or r code?
Thanks
Old 12-06-2015, 04:45 PM   #6
olerodder's Avatar
Region: Oregon
How about taking some pictures of the motor. Is it a 351w, 351C, 302, or ???
351w has 7 bolts to hold the valve cover on and the 351C has 8. Also, the 302 and 351w block has the intake bolts going at a 90 degree angle to the block...meaning the bolts are pointing straight towards the ground.
The number you posted doesn't mean anything to me....can you find the block casting number like DZ, CO, with numbers and letters and should be just above the starter. It should read something like D1ZE-6015-BA.
If you Mustang is a 73, they made no R code engines for the 73. If you Mustang was a 72 then yes, there could have been an R code motor in it....although R codes would be a 429....if the vin is H then the car came from the factory with a 177 hp 351-2 barrel. If the vin was a Q it would have been a 351-4 barrel.
If the motor is actually a Q code it could be a 351-CJ and could have 4 bolt mains which would make the motor quite valuable. We need to know the Ford casting number before we can make anymore educated guesses.
Old 12-06-2015, 07:43 PM   #7
Thanks for your help. I will post the details once I get the motor.
convt top alignment pin - Looking 4 MustangBob2012 2011-2014 V6 Mustang 0 08-18-2013 08:00 PM
Do I need rollbar in convt? Peterzinyou At the Track 10 04-24-2013 01:32 PM
P0301 engine code White Stalion Pre-2005 V6 Mustang 7 01-19-2011 08:26 PM
FORD MUSTANG BRAINIACS what does r-code and/or c-code mean? kele74 Classic Mustangs 4 03-16-2010 05:12 PM
Coupe to Convt LeeLee Classic Mustangs 8 09-04-2006 08:30 PM
01:43 AM
