67 Electrical Issue - Mustang Evolution
Old 01-01-2016, 11:27 AM   #1
Aggiesrok's Avatar
67 Electrical Issue
My front right blinker does not blink, but lights up when the headlights are on. When the right blinker is on, you can hear a blinking sound coming from the distributor. It's a Duraspark (no points). When I disconnect the coil wire from the Duraspark, the distributor stops making the blinking sound.
So do you think it's an issue in the Duraspark box or is it the headlight harness? I'm about to check the harness, but wasn't sure if someone had a similar problem in the past. Thanks.
Old 01-01-2016, 12:53 PM   #2
Tyoung68's Avatar
I have a similar issue with my blinkers not blinking but lighting up when the headlights are on. I'm thinking its a ground issue for me might wanna check that out in yours
Old 01-01-2016, 01:18 PM   #3
Aggiesrok's Avatar
I can't find an engine ground strap. I also noticed a spark from the starter cable at the starter relay. I'm going to install a ground strap and hopefully that solves the problem. My battery is grounded to the engine, but nothing else.
Old 01-01-2016, 05:48 PM   #4
Commercial Member
matcox83's Avatar
Grounds are usually the culprit for the weirdest electrical problems. You do need a ground from the firewall to the block. That completes the circuit so the grounds don't find their own way home.
Old 01-01-2016, 06:08 PM   #5
Aggiesrok's Avatar
I can just add a cable to the block where the battery neg is connected and bring it to the frame, right?
I ran new wires from Duraspark to the starter relay and cleaned up some connections on the relay. Now the clicking in the distributor is gone. So a little progress.
Chevy runs deep, don't step in Chevy.
Old 01-01-2016, 10:42 PM   #6
Aggiesrok's Avatar
Update
I ran a ground strap from block to frame. This seemed to fix a lot of little issues. I think the fuel gauge is correct again, starter seems stronger as well as some little stuff.
But, a new issue.
The car starts and runs, but the key will not turn off the engine. All positions allow the engine to continue. If you try tap it to start it kills it.
Also when the key is in ACCY position the radio comes on as expected and when the key is in ON position the radio comes on as expected and turns off when key is in OFF position.
So my first thought is that the relay is actually messed up.
Any thoughts are appreciated. Thanks.
Old 01-02-2016, 01:15 PM   #7
ER12883's Avatar
As a general comment more than specific answer, I'd first get under the dash and look for loose connections and broken/frayed wires. I have chased electrical issues and thrown parts at them only to find out a wire had pulled out of a harness.
Good luck and keep us posted!
ER12883 is offline   Reply With Quote
Old 01-03-2016, 10:03 AM   #8
Aggiesrok's Avatar
So I installed new relay and the battery died after a few cranks. New battery and all is good. The block to frame strap fixed most everything and the relay was bad.
Now lights are brighter and everything just seems to be a little better.
My 13' electrical issue bluemonster13 2011-2014 Mustang GT 19 12-19-2012 03:20 PM
electrical issue. Rob94gt 1979-1995 Mustang GT 4 08-23-2012 08:16 PM
electrical issue? Slvr01GT 1979-1995 Mustang GT 9 03-26-2012 03:33 PM
Electrical issue Seattle66 Classic Mustangs 10 02-24-2012 11:12 AM
Still chasing electrical issue... Project Pony Pre-2005 V6 Mustang 2 01-31-2012 05:08 PM
07:36 AM
