High output alternator and Ammeter - Mustang Evolution
Old 01-12-2016, 07:59 PM   #1
I am planning to install a 140A, single wire alternator on my '66 and have read that I need to bypass the ammeter. Would simply disconnecting the ammeter from the gauge cluster suffice or is more required? I'm installing a new wiring harness as well, and will not have the alternator harness installed as the alternator is a single wire unit.
Thanks in advance for the help!
Teach your kid to have a car problem and they won't have money to have a drug problem
RonVernon is offline   Reply With Quote
Old 01-12-2016, 09:33 PM   #2
Tyoung68's Avatar
Are you getting an internally regulated alternator?
And what do you mean your getting a new harness?
Old 01-13-2016, 04:38 AM   #3
Yes, single wire, internally regulated.
I am installing a new wiring harness. Actually, I'm installing all new wiring from the dash forward, leaving only the tail light harness untouched
Old 01-13-2016, 09:23 AM   #4
Tyoung68's Avatar
Well then you really won't need to Un hook anything behind the dash all you'd need is to ground the alt and hook a power wire to the bat. And then as a volt meter if you want one.
Old 01-13-2016, 01:38 PM   #5
Koryak's Avatar
The problem with old analog ammeters is they are reading current through a shunt and the design maxes out if your 140 Amp alternator is full on. I'd either jumper the ammeter terminals with a solid heavy wire or replace it with an aftermarket OEM replacement ammeter that reads at least + 80 Amps during charging. With the stock ammeter jumped terminal to terminal the reading will stay at 0 or show a very low charge / discharge reading.
Koryak is offline   Reply With Quote
Old 01-13-2016, 11:26 PM   #6
Tyoung68's Avatar
Well with the single wire Alts there's nothing hooked up to the volt regulator or amp meter circuit. I had the same on my car but upgraded the gauges shortly after too
Old 01-14-2016, 09:17 AM   #7
Koryak's Avatar
With the modern alternator's output wire connected directly to the battery you're bypassing the ammeters shunt and not a problem. But to get a charge / discharge reading the ammeter has to be in the circuit between the alt and battery. What I don't like about a direct battery connection is you're bypassing a safety fuseable link in the stock wiring harness.
Old 01-14-2016, 11:02 AM   #8
Tyoung68's Avatar
I ran mine though the starter solenoid with a fuseable link. Pretty sure my alt. Came with it too
Old 01-15-2016, 12:33 PM   #9
Koryak's Avatar
Sounds good. I had a '67 & '70 and doubt if their alternators could keep up with a new Mustang's electrical appetite!
Old 01-17-2016, 07:58 PM   #10
I'm running the alt wire through a 175 amp fuse before hitting the battery. I've decided to not connect the ammeter and just tape the wires behind the instrument panel. Plan is to install a new cluster with digital gauges in the near future
Sound of a HIGH OUTPUT Vortech Supercharger V3 BarricadeGT10 Pictures and Videos 1 03-21-2013 11:41 AM
1966 Mustang ammeter problem Gatorlee12 Classic Mustangs 2 03-30-2012 08:54 PM
annual output? douchi Pre-2005 V6 Mustang 4 06-09-2007 02:00 AM
High Output V6??? Rellik The Bar 1 01-05-2004 04:10 PM
Stock MACH deck output power/Basic amplifier question DropTop_Stang Mustang Audio & Video 0 08-10-2003 11:00 PM
06:45 AM
