CFM 500 or CFM 600 What's The Difference ? - Mustang Evolution
Old 02-24-2016, 02:11 PM   #1
Region: Nevada
Hi Guys (Newbie Here)
I'm having my ' 66 Mustang Covert. troubling fuel injection system taken out and replacing it with:
EDELBROCK 4 BARREL CARB. & CHROME MANIFLOW.
I don't know what CFM I should go with the carburetor ?
500 CFM or 600 CRM ?
Can you guys tell me which CFM is BEST for my car and WHY ?
THANK GUYS
Schooner
GOD
bless you ALL
SCHOONER is offline   Reply With Quote
Old 02-24-2016, 03:18 PM   #2
Depends on your engine size and application. If you have a 289 or 302 either should be fine. Difference is minor and probably in fuel efficiency and how high you redline max rpm. Use an online cfm calculator to determine which is best. For street you won't notice a difference. But don't go over what's recommended. You'll experience hard starts and rough idle.
Port139 is offline   Reply With Quote
Old 02-24-2016, 08:12 PM   #3
BA68 mustang's Avatar
Holley would reccomend a 390 cfm, that's fine if you don't plan on tracking it but it's going to make no power above 5k, I'd do the 500 cfm but I personally don't like the eddy carbs but then again I've never spent the time to learn how to tune them id go with a Holley 570 street avenger
Smoke tires not drugs
BA68 mustang is offline   Reply With Quote
Old 02-24-2016, 08:31 PM   #4
oxfordwhite's Avatar
Used to run a 650 Holly on my 65 2+2. It was a 289 with a 180 Edlebrock Hi-rise and the 289 Hypo cast iron headers. Perfect set up. Car came with a 600 Autolite Vacume secondaries 4bl. That was a good carb when she was stock.
oxfordwhite is offline   Reply With Quote
Old 02-25-2016, 04:32 AM   #5
Mlarv5's Avatar
Stock engine I would stay with the 500 CFM. Even then you may have to jet it down a bit. I have seen a lot of people over the years use 600 or 750 carbs for a little while then jet them down to 400. You will be able to tell when you hit the gas hard to take off and there is a hesitation then it goes like H---. This is a sign of to much gas at one time.
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
CFM's 11 sec V6 CYCLON37 2011-2014 V6 Mustang 18 05-22-2012 12:56 AM
Dyno-Day and Cruise-in Longwood, FL, 2nd annual by VMP & CFM, $50 for 2 runs justin00stang Regional Mustang Discussion 0 02-15-2008 08:54 PM
May 5th Central Florida show & dyno day ($40 for 2 runs) by VMP & CFM, free food justin00stang Regional Mustang Discussion 0 05-01-2007 11:00 AM
TKO 500/600 OR T56 Js281GT 1996-2004 Mustang GT 15 01-27-2006 09:23 PM
06:56 PM
