9 inch rear end flange - Mustang Evolution
Old 03-29-2016, 03:26 AM   #1
goejo's Avatar
Hello Gentlemen,
Being in the process of rebuilding my 65 9 in rear end, I have to revert to your expertise concerning the different versions of companion flanges/pinion yokes there are. Note that my Stang is a K hence the 9 in rear end.
The type of flange/yoke that I would expect is shown in the second image just for reference.
The companion flange that was installed on my car is pictured in the first image. As you can see it has a metal ring around the bottom part of the flange. I removed it from the pinion last night so I cannot tell yet if they are one part or if this ring can be removed. It is fairly heavy and I would guess it is some kind of dampener but it is not typical, even for K-codes.
While I did dome research what it really is and what application it comes from, I had no luck. Does anybody have an idea?
Thanks,
Jo
goejo is offline   Reply With Quote
Old 03-30-2016, 03:35 PM   #2
goejo's Avatar
Update
To further investigate, I cleaned the pinion yoke a bit and found some more numbers. C3AW-4980. Hope that helps...
Sent from my iPad using Tapatalk
Old 03-30-2016, 06:40 PM   #3
Tyoung68's Avatar
I found this
http://www.network54.com/Forum/74182...truction+today
Tyoung68 is online now   Reply With Quote
Old 03-31-2016, 11:40 AM   #4
goejo's Avatar
Originally Posted by Tyoung68 View Post
Hello Tyoung68
thanks! That was a sad story! are you reading it that it came with a Galaxie or a Bronco - got kind of confused.
I found also something but there it seems clear that it was a Galaxie: http://www.fordmuscleforums.com/gala...nion-yoke.html
Jo
Old 04-02-2016, 02:30 PM   #5
olerodder's Avatar
Region: Oregon
I doubt that the rear end came from the factory like that. Both of my K code Mustangs, 65 and 66 had regular nine inchers....looks like it came out of a bigger car like Galaxie or Fairlane.....although my 63-1/2 R code Galaxie didn't have one.
Ford did a lot weird stuff on the assembly line back in the 60's.
What gears do you have the Mustang?
Old 08-13-2016, 04:16 AM   #6
goejo's Avatar
Hello olerodder,
Apologies for the late reply.
When I got the car, there was one differential installed (obviously) and a spare on the side. The installed one was a 3.25 and the spare is a 3.9. According to the owner the spare 3.9 was original to the car and the 3.25 w installed after the other one had seized. The weird thing is that the axle code is '5' and the transmission is 'E'. since it is a 4speed manual transmission, i thought the codes were interchanged.
Old 08-13-2016, 11:28 AM   #7
olerodder's Avatar
Region: Oregon
It should be a 3.89 as Ford never made a 3.90 that I am aware of. Both of my K Code mustangs came with 3.50's or E code....one was an open and the other had the very rare Equa-Lock or A code. If the 9" that is in there is an E code it should have 3.50's, the 3.25 would have been a D code.
To find a 3.89 in a 65/66 K code Mustang would be extremely rare as only 1% of the K code Mustangs came with option and most probably had a posi rear end.
Do either of the rear ends have a posi unit or are they both open.
Also, did the car come from the States or was it an export model?
So, the rearend is an E code and transmission is a 5 code...right???? Body tag numbers were never interchangeable....at least in US bound cars...I've only see 2 export Mustangs and I don't think the numbers were interchanged...is this a real Ford tag or a repop? How about some pictures.
Old 08-14-2016, 03:11 PM   #8
goejo's Avatar
You got me confused there so I went and counted the teeth again. The one that was supposedly the original has 43/11 teeth, which makes 3.909.
The other one was a 3.25 (39/12). Both are open differentials.
As you see from the tag it is an export model (to Canada).
When I ordered a new axle tag from Marti, I also enquired about the warranty plate codes. Their reply was "Your codes are correct. The transmission code is E instead of a 5 because it is a Canadian car." when I asked for more info on this, I got no reply.
2013 cat converter flange nut dudley279 2011-2014 Mustang GT 0 08-10-2014 02:58 PM
Exhaust flange gasket 1996v6stang 1996-2004 Mustang GT 11 01-12-2013 05:57 PM
anyone know where to buy exhaust flange's? rebeltx 2011-2014 V6 Mustang 15 10-26-2012 07:09 AM
Exhaust manifold flange bolts jwhayne0001 1979-1995 Mustang GT 14 12-30-2011 06:49 AM
01 GT mufflers from H pipe flange back. No tailpipes Player Pony Mustang Parts for Sale and Wanted 0 06-06-2005 11:46 PM
03:04 PM
