Paint stripper - Mustang Evolution
Old 12-17-2016, 08:08 PM   #1
Region: Iowa
Paint stripper
The casing around the headlights what would you all recommend to remove 4 layers of paint
Sent from my SM-N920V using Mustang Evolution mobile app
65 coupe is offline   Reply With Quote
Old 12-18-2016, 09:34 PM   #2
olerodder's Avatar
Region: Oregon
I assume you are talking about the fender extension and headlight door???
These were originally made pot metal and if damaged are really hard to fix.
I have always used Klean-Strip which is an aircraft paint remover. I used this on two 65/66 Mustangs and one car had 5 coats of paint. It took a couple of applications to get to bear metal though. Make sure you use it in a very well ventilated area and use a respirator that is rated for toxic fumes and solvents...also use rubber gloves and safety glasses and don't wear good clothes or shoes...after stripping to bear metal use a metal prep to prevent rust..IMHO
How to paint Brake Calipers with the G2 paint kit Seatown Stang Mustang DIY and Technical 7 08-02-2016 05:44 PM
Paint Help ThatsCoolBro Mustang Paint, Appearance & Detailing 4 07-19-2014 07:07 PM
To paint or not paint carbon fiber poloka 2011-2014 Mustang GT 11 08-18-2012 11:20 AM
Paint Dogbitdude Pre-2005 V6 Mustang 2 06-03-2012 02:05 PM
Cop Blows Load on Stripper bluemustang The Bar 6 02-27-2007 01:58 PM
04:56 AM
