9 inch almost done - Mustang Evolution
Old 02-21-2017, 06:45 PM   #1
Aggiesrok's Avatar
9 inch almost done
Finally done tomorrow. Of course had setbacks. Needed new brake back plates, yoke issue, then drive turned out to be crap. New drive shaft ready tomorrow. So now it's a 9", 31 spline, 11" new drums, posi, 3.50 gears and new 3" drive shaft. Good bye 8 inch 2.79.
Should be awesome.
Chevy runs deep, don't step in Chevy.
289 - Holley 4150 570cfm; Performer intake; mild cam; MSD HEI; 302 heads; Roller Tips; Hedman Tri-Y headers; H-pipe w/Flowmaster 40's; 9 in posi 3.50; 205/50-17F; 225/50-17R.
Old 02-22-2017, 04:51 PM   #2
Aggiesrok's Avatar
Another unforeseen delay. Driveshaft is garbage, so waiting on a new one.
Old 02-23-2017, 01:45 AM   #3
Sweet!
That's a nice upgrade!
Old 02-23-2017, 09:11 PM   #4
Aggiesrok's Avatar
Back on the road. Super sweet. Brakes better and gears made a huge difference. Speedo is now off about 30%, some big gear difference.
Old 02-23-2017, 11:35 PM   #5
Tyoung68's Avatar
What made you chose that instead of a 8.8?
Old 02-24-2017, 09:20 PM   #6
Aggiesrok's Avatar
Everyone uses the 9 inch. Tons of chevy builds use a Ford 9 inch. They're easy to install and bulletproof.
Old 03-24-2017, 03:02 PM   #7
Aggiesrok's Avatar
Any value in the old 8" setup?
Old 03-24-2017, 07:31 PM   #8
caveeagle's Avatar
8" fords are still very good. Especially if you have the 67+ unit with the cross braced ## casting, instead of the one with the Flat == casting supports in the case front.
They are plenty strong, can be fitted with a trak-lock diff and have all the same advantages as a 9". I have know some vintage mustang guys who prefer them for a little less rolling resistance.
..But with 2.79 gears, it would need to be upgraded to sell for much more than just core value.
caveeagle is offline   Reply With Quote
Old 03-24-2017, 08:02 PM   #9
Yeah if you are making ludicrous power going all the way to plaid then 9" is the way to go. Not sure I'll ever make enough where an 8.8" can't get it done tho...
that's what she said!
Old 03-24-2017, 11:11 PM   #10
Tyoung68's Avatar
8in's go for like 250 on my local Craigslist
Old 03-25-2017, 12:36 AM   #11
Hahaha
Pee-pee humor!
Old 03-25-2017, 07:17 AM   #12
Teeheheheheheeee
Sent from my LG-LS997 using Mustang Evolution mobile app
Old 03-27-2017, 12:32 PM   #13
caveeagle's Avatar
Plenty of people putting down 700+ HP through a 8.8"
Depending on what your building... There are other advantages to using the 9" platform.
If you get the right version, you can swap one right over to replace an existing 8" housing. Even the brakes can be swapped if you have the right large/or small bearing version.
Swapping an 8.8 into a vintage mustang can be done, but you might have to deal with new spring perches, possible offset pinion position and converting to a disk/disk MC.
Mark...
04 Torch Red SVT Cobra (original owner)
67 CA Red Vert, 289 4V, 4Speed (almost done..)
67 Black Deluxe Coupe, 289 (Sold)
67 Coupe I6 to 302 conversion (Sold)
Old 03-27-2017, 08:54 PM   #14
Aggiesrok's Avatar
Yeah went with a posi 9. Just wasn't sure if I could get any money for the old 8".
15 inch wheels MachityMach Other Special Edition 6 12-07-2016 05:52 PM
1.5 Inch drop mustangz 2011-2014 Mustang GT 67 03-08-2015 12:37 PM
3 inch? Torchredfrankie 2005-2010 Mustang GT 8 08-05-2013 09:10 PM
15 inch or 17 inch rims Vistablue Mustang Wheels & Tires 21 01-11-2013 06:15 AM
3.5 inch or 4 inch tips? 2002Gt 1996-2004 Mustang GT 73 06-19-2011 10:29 PM
03:59 AM
