Throttle problem 1986 capri 5.0 - Mustang Evolution
Old 03-07-2017, 10:26 PM   #1
I have replaced the throttle body module twice, replaced spark plugs and wires but still having problems. After starting the idle will go up and down 900-100rpms. It will run fine after a warming up until I get to a long red light. Sometimes at the light it will start going up and down and sometimes even shut down. It will start just fine when this happens. But other times at a red light it will ram up to over 3000rpms and if I do not have my foot firmly on the brake it will try to lurch and throw me into cross traffic. After getting a green light and driving for a 100 feet or so it will idle sometimes and starts running just fine. It does not do this all the time but I never know when I may get thrown into traffic. Can anyone offer me some help on fixing this problem?
pearsam is offline   Reply With Quote
Old 03-08-2017, 12:09 AM   #2
Have you tried replacing the Idle Air Control valve?
Old 03-08-2017, 08:29 AM   #3
IACV
No, I have not. I even went to a mechanic and he kept looking looking through the plugs, wires, and Idle body. I will definitely try this. I will let you know if it works. Thanks
Old 03-08-2017, 10:31 AM   #4
I recommend replacing it with one manufactured by either Motorcraft or Hitachi.
Also, disconnect the negative battery cable before replacing the IAC. This will clear the computer memory, and force it to relearn the new idle trims.
02 GT throttle problem Romes02GT 1996-2004 Mustang GT 4 01-04-2016 09:19 PM
Problem with throttle cable Crowned1 Pre-2005 V6 Mustang 4 08-30-2013 05:35 PM
Throttle body problem Stang.racr 2005-2010 Mustang GT 9 06-05-2012 12:49 PM
Throttle Problem jjsg09 1996-2004 Mustang GT 11 04-17-2012 06:44 PM
06 Throttle Body Problem Snake 42 2005-2010 Mustang GT 2 11-02-2007 02:55 PM
03:59 AM
