Alignment quick help - Mustang Evolution
Old 05-05-2017, 03:44 PM   #1
Tyoung68's Avatar
So I've never had any luck getting my car aligned so I need some help I have all new everything and everything had settled in but I have had my front tires wear out in 8k miles and according to the paperwork from the Shelby drop kit my specs should be
Camber -2 to -3
Caster +2 to +4
Toe 0-1/16 out
Are those specs good? My tires wear heavy on the inside on both
Old 05-07-2017, 04:13 PM   #2
Wink
Those look like typical specs for a high performance front end alignment.
I think that the problem is, you aren't driving the car hard enough... Because if you were, you would be wearing out the entire tire evenly at 8k miles, instead of just the inside.
This is one of the perils of having a staggered tire/wheel setup, you can't rotate the tires!
You can try cutting the camber in half, and see if that helps with the tire wear. You may notice a slight decrease in cornering performance though. Everything is a compromise when it comes to modifying vehicles.
Old 05-09-2017, 07:46 PM   #3
Tyoung68's Avatar
Well I'm looking for for medium performance lol I mean it's a six and maybe had 180 horse and can only break loose in the rain I just need to get my hands on a set of turn plates or figure out how to make some.
Alignment PiojoA7x Pre-2005 V6 Mustang 11 08-28-2014 09:56 PM
Alignment/ 610swolf 2005-2010 Mustang GT 1 11-04-2013 08:49 PM
Alignment Ohdang1990 1979-1995 Mustang GT 8 10-11-2013 02:44 PM
Quick question need a quick answer about exhaust manifolds Ghostedmind Pre-2005 V6 Mustang 7 03-15-2013 12:36 AM
alignment help???!!! fordracing63857 1979-1995 Mustang GT 5 08-13-2012 06:56 PM
03:58 AM
