C4 - Slipping and Gurgling - Mustang Evolution
Old 08-30-2017, 11:23 AM   #1
Aggiesrok's Avatar
It slips in D and doesn't want to shift to 2 until it really warms up, then it doesn't want to go into 3, but eventually does. Reverse barely works.
So I changed the filter and fluid. Fluid mostly red/orange and some gray sludge in pan (not too bad - no shavings). I got 6 1/2 quarts out and put in about the same.
Now reverse barely engages cold and warms up to not work at all. D is about the same as before the fluid change.
There is a gurgling sound when in P and revving the engine, which sounds like it's coming from the bell housing area when inside the car. Which would indicate that it's low on fluid, but it's fine on the dipstick when warmed up.
The C4 was rebuilt as stock 3 years ago at a local trans shop.
289 probably low 300's HP / 9 inch posi 3.50. The rear end was a swap from the stock 8 about 4 months ago.
289 - Holley 4150 570cfm; Performer intake; mild cam; MSD HEI; 302 heads; Roller Tips; Hedman Tri-Y headers; H-pipe w/Flowmaster 40's; 9 in posi 3.50; 205/50-17F; 225/50-17R.
Old 08-30-2017, 11:01 PM   #2
If I have to guess, I'd say that the transmission is not building enough fluid pressure to function properly.
Every time that I have removed the pan on an automatic transmission lately, the bolts have become loose on the valve body. I've even found one or two laying in the bottom of the pan!
Possibly, something similar has happened to your transmission.
Old 08-31-2017, 01:13 PM   #3
Aggiesrok's Avatar
Thanks. I'll check that. I think I'm going to flush it.
Chevy runs deep, don't step in Chevy.
Old 09-15-2017, 10:37 AM   #4
Aggiesrok's Avatar
I decided not to spend any more time or cash on this trans. I ordered a TCI Streetfighter, but it's still a week or two out. So I thought I would try to get the old one driveable until then. Added a half can of Sea Foam and drove about 20 miles. Seemed a little better, but still would not go into 3 and Reverse barely worked. I went to back into the garage since R didn't work and now it moves forward in R N D 2 1. I had to turn off the engine in order to back down the driveway. I guess the whole thing is just fried at this point.
Gurgling with O/R Hpipe martinez8191 2011-2014 V6 Mustang 3 11-18-2015 02:04 PM
Slipping jpsgtcs 2005-2010 Mustang GT 3 05-22-2015 08:58 PM
clutch slipping? satin06silver 2005-2010 V6 Mustang 8 08-15-2013 08:56 AM
89 clutch slipping.? Vazqueza90 1979-1995 Mustang GT 2 05-11-2013 04:33 PM
Starting Issue (Gurgling) Davo_281GT 2005-2010 Mustang GT 7 03-22-2013 01:18 PM
03:59 AM
