Car Shuts Down While Driving - Mustang Evolution
Old 03-20-2018, 01:04 PM   #1
Aggiesrok's Avatar
The car starts fine and drives fine, but when in city traffic it will sputter, cough and shut down after 15-25 minutes. I thought is was fuel level related as it always happened just below 1/4 tank, but happened twice yesterday, 2nd time after a fill up. It will just turn over and over like it needs fuel. Finally after trying to flood and spraying a lot of carb cleaner down the throat, it starts and runs, drove 15 minutes home, (took about 15 minutes to re-start).
67 289, edelbrock performer intake, Holley 570 Avenger, mild cam, edelbrock fuel pump, power brakes, manual steering, C-4 (2300 stall), 9" 3.50 posi. Timing 14 BTDC, Vacuum 19-20, idle at 650-700. just changed plugs and were clean, mixture 1 3/4 out each side, fuel pressure was 6 psi, but then went to 0 and I drove it 15 minutes home, still 0 at home (gauge probably hot). After it died, I can see fuel squirt in the carb and the fuel bowls were adjusted to just leak when screw removed (both bowls), Engine temp gets to 200 to 205 in traffic.
289 - Holley 4150 570cfm; Performer intake; mild cam; Pertronix HEI; 302 heads; Roller Tips; Hedman Tri-Y headers; H-pipe w/Flowmaster 40's; 9 in posi 3.50; 205/50-17F; 225/50-17R.
Old 03-20-2018, 01:40 PM   #2
Have you checked the leads and ground for the fuel pump?
Old 03-20-2018, 01:56 PM   #3
Have you checked for spark immediately after the engine dies?
Old 03-20-2018, 02:48 PM   #4
Aggiesrok's Avatar
It's a mechanical pump, sorry left out that detail.
Old 03-20-2018, 02:51 PM   #5
Aggiesrok's Avatar
No, do you think it could be the coil? It's mounted to the head, possibly getting hot? The distributor is a new Pertronix (about 1 year old, no points) and the coil is Flamethrower about same age.
Old 03-20-2018, 02:53 PM   #6
Aggiesrok's Avatar
I just checked the fuel line to the tank and it gets about 2-3 away from the exhaust pipe in one spot, but that's it. Not sure if that's close enough to cause vapor lock in the line.
Old 03-20-2018, 03:17 PM   #7
Yes. Definitely check for spark the next time this occurs.
At first my suspicion was the ignition module in the HEI, but since you have a Pertronix, I'm now leaning towards a failing coil.
But check spark first. That way you can positively eliminate fuel as the culprit, and focus your attention on diagnosing the ignition system.
Old 03-21-2018, 04:43 AM   #8
Strange Mud's Avatar
spray of ether will tell you if it's fuel or electrical mister bottle of water will be nice cause FIRE
gut is electrical something getting hot.....distributor cap?
Strange Mud is online now   Reply With Quote
Old 03-21-2018, 08:58 AM   #9
Aggiesrok's Avatar
Bench checked MSD Blaster coil:
0.9 ohms across Pos & Neg
5180 ohms across Pos & Coil Terminal
5180 ohms across Neg & Coil Terminal
These readings were taken on a completely cold coil.
Old 03-21-2018, 09:12 AM   #10
things like coils/dist caps/etc is when they get hot you'll get shorts that never show up on meter voltage. 40K plug voltage will become a problem.
Old 03-21-2018, 09:55 AM   #11
I believe that the coil to negative should be 6000-15000 ohms.
Pertronix has a somewhat "mixed" reputation for reliability... Some seem to swear by them, and some who have been set afoot one too many times, swear AT them.
The coil going bad seems to be the most common problem. Some will argue that the oil filled coil needs to be mounted horizontally with the terminals at the 3 and 9 o'clock positions, to prevent them from failing prematurely. Others say that it makes no difference, horizontal or vertical.
Some folks have ditched the electronic ignition and gone back to using points and condenser.
Whichever ignition system is used, it is always prudent to carry along spare parts to replace the components that are most frequently prone to fail.
Old 03-21-2018, 11:00 AM   #12
Aggiesrok's Avatar
Ok, I just talked to Pertronix Tech support.
He told me to unplug coil to Dist.
Connect Coil Neg to Ground
Set Meter to Volts
Put Red lead on Coil Pos
Put Black lead to Ground
Crank Engine for 5 seconds
Voltage over 9 volts is good and less is bad
My Reading is 6.8v, so I have a short or losing voltage somehow. Had some brake light issues and I guess it's a short. After the motor heats up, the available voltage drops below a running level. So problem identified, but not solved yet. I really hate looking for shorts, but at least it should be isolated to the brake circuit.
Old 03-21-2018, 12:12 PM   #13
No. You don't have a short. Not there anyway.
That wire going to the coil is a resistor wire. It drops the voltage to about 7 volts for the original points-type ignition.
You can just bypas that wire, and run a wire directly from the ignition switch to the coil to provide 12 volts.
Don't throw that resistor wire away though... You might need it again someday.
Old 03-21-2018, 02:33 PM   #14
forgot about those......older folks are OK when we remember.
Old 03-21-2018, 06:37 PM   #15
SVOGT302 is offline   Reply With Quote
Old 03-22-2018, 10:00 AM   #16
Aggiesrok's Avatar
Like in ***** runs deep, don't step in *****
Old 03-22-2018, 10:10 AM   #17
Aggiesrok's Avatar
I think that wire is directly from the ignition, I've had to replace some wires in the past. I don't have points, it's Hall effect.
Two wires on Positive side of the coil: Ignition and + Distributor.
Two wires on Negative side of coil: - Distributor and Tach.
Maybe I'm not understanding which wire you're referring to. The tech said I should be getting 9-10 volts. I have some sort of short or broken wire for the brakes.
Old 03-22-2018, 01:35 PM   #18
I would assume that someone replaced or bypassed the resistor wire during the course of installing the electronic ignition. It just seems odd that your voltage reading is about the same as would be expected with the resistor wire in place.
Just something to investigate during your diagnosis...
Old 03-22-2018, 01:41 PM   #19
Aggiesrok's Avatar
Yeah it's kinda strange. When I got it had an old Pertronix distributor with an ignition box. There has been a lot of monkey business with this car.
What the tech said makes sense, but it looks more like I have an almost broken wire for the brake light. In the harness that goes into the light switch, it seems that you can move the harness and the brake light works. The wire is good all the way from that point to the trunk.
Maybe it's still the coil. I'm going to fix the wire and see what that does.
On a side note, I'm thinking about replacing my fuse box with one of the auxiliary fuse blocks, it's got 4 hot and 3 ignition hot with a 50 amp relay for $68. Those OEM fuse blocks are garbage.
Old 03-22-2018, 07:59 PM   #20
It certainly can't hurt to fix the known problems and upgrade the electrical system. A half-century old vehicle can probably use some TLC.
Keep us posted!
Old 03-23-2018, 11:01 AM   #21
Aggiesrok's Avatar
I was able to move the harness enough to get the connection for the brake lights. I'm still going to replace the wire, but I checked the voltage on the coil as instructed and I still get 6.8 volts. So I don't know where I'm getting a voltage drop.
I've got a 73 F100 that I'm going to swap out the coil and see what results I get. It still seems to be the coil to me at this point.
Old 03-23-2018, 01:35 PM   #22
Hello, 7v is normal, there is a resistive wire near the contact, below the dashboard. This thread is pink. It was enough to remove it to have the 12v to the coil.
marc_spierk is offline   Reply With Quote
Old 03-23-2018, 03:47 PM   #23
I'm beginning to believe that it is possible that whomever originally changed the ignition system on Aggies car from points to electronic ignition, may have overlooked removing the resistor wire from the coil lead. This might explain the failure of all subsequent ignition systems installed on the engine.
The wire is white with a pink stripe, correct?
And welcome to the forum!
Old 03-24-2018, 10:50 AM   #24
Aggiesrok's Avatar
So you guys are good and you won't believe what I found.
They spliced the pink wire and green/red stripe (alternator) into a red wire going into the ignition switch and used the wrong pigtail at the firewall which changed the pink wire to blue and on to the coil. So the pink wire was being used, but undetectable until unwrapping the main harness behind the instrument panel.
So now, I'll run a new wire straight from the ignition to the coil. This should improve performance as well if I'm getting higher voltage to the coil?
I'll post an update after getting this done. Thanks again.
Old 03-27-2018, 09:07 AM   #25
Aggiesrok's Avatar
I removed all of the pink wire and ran new wires from starter relay to coil and ignition switch to coil. Now I am getting 8.9 volts when testing coil by method suggested by the tech. I was only getting 3 volts at ignition on before starting and now it's 10.4 volts. I'm surprised the distributor worked with the pink resistive wire in place. It starts up great and sounds stronger, but also seems a little lean. This is good, since I'm should be getting a lot more spark, so after installing new fuse block I'll readjust the carb mixture screws and see what it's like.
Old 03-27-2018, 09:25 AM   #26
Hopefully that will solve the stalling problem.
Car shuts down by its self LeoGMR4558 1996-2004 Mustang GT 7 11-21-2015 12:53 PM
Belt squeeks then car shuts off RaysV6 Pre-2005 V6 Mustang 4 07-01-2013 03:01 PM
Help my car shuts off mustangGT5.0 1996-2004 Mustang GT 6 11-15-2012 09:03 PM
Car shuts off when WOT vinnygt Mustang Wheels & Tires 14 12-29-2011 12:02 AM
2006 Ford Mustang Shuts Off While Driving? Laurenz General Mustang Discussion 2 12-16-2011 09:59 AM
03:36 PM
