200 engine - Mustang Evolution
Old 09-01-2008, 06:43 PM   #1
200 engine
I am going to buy a 200 engine to rebuild and was wondering how to identify a 200 from a 170.
my66stang is offline   Reply With Quote
Old 09-01-2008, 06:52 PM   #2
Scut95's Avatar
Re: 200 engine
there should be a casting number on the block. You have to get the number and look it up and it will decode everything. It will tell you where and when it was made, and it should also tell you what year and what vehicle it is from.
95 GT- Sold
09 Hyundai Elantra Touring-new ride.
Looking for the next project car now
Old 09-04-2008, 10:48 AM   #3
Herbstang's Avatar
Re: 200 engine
The 170/200 sixes all look the same. The 170ci six has three freeze plugs in the block.The 200ci six has five freeze plugs and has a three-bolt water pump.
Old 09-28-2008, 11:41 PM   #4
Re: 200 engine
As stated in the above post, count the freeze plugs , the 200 I6 will have 5 freeze plugs on the right side of the block.
DARE TO BE DIFFERENT: STAY INLINE
______________
1966 Mustang Convertible, Candy Apple Red, black interior, black power top, 200 CID I6, Autolite 1100 carb, C4 Auto trans (converted from 3 sped manual), Scarebird 4 lug disc brake conversion and dual master cylinder swap in the process.
RagHead is offline   Reply With Quote
Old 11-03-2008, 09:36 AM   #5
SC_STEEDA's Avatar
Re: 200 engine
I have a 66 I6 and i was wondering what a freeze plug is so i can tell what mine is?
2003 LAND ROVER DISCOVERY-These are amazing off-road vehicles to be stock!
2001 3.8L TOTALED
CAI; HELI-X Throttle Body Spacer; MOTOBLUE Pulley Kit 42%; Crank 5% Water; Harmonic Balancer; WIRES; EIBACH Sport Springs; FLOWMASTER Dual 40 Series turndowns!
"You want something. Go get it. Period. Don't ever let someone tell you... you can't do something."
SC_STEEDA is offline   Reply With Quote
Old 11-03-2008, 12:26 PM   #6
Herbstang's Avatar
Re: 200 engine
A freeze plug is usually a round, dish shaped piece of metal, which is pressed into the engine block and the engine head. There are multiple sizes, and usually multiple locations depending on the engine, freeze plugs are located in the back of a head or block They may also be found on the sides of an engine, under an exhaust or intake manifold
A true freeze plug is an expansion plug located in the side of an engine block that is supposed to protect the block against freeze damage. Water expands when it turns to ice, and if the coolant does not have enough antifreeze protection it can freeze and crack the engine block. The freeze plugs are supposed to pop out under such conditions to relieve the pressure on the block.
66 200 cid rebuild help Naval Gator Classic Mustangs 0 11-25-2008 11:44 AM
Anyone with 20/200 vision? Monkey The Bar 0 05-07-2004 08:03 PM
$200 fast64 Pre-2005 V6 Mustang 13 12-25-2003 06:29 AM
$200+ complete supercharger, help Stang01 Pre-2005 V6 Mustang 3 07-20-2003 04:07 PM
08:55 AM
