third member problems - Mustang Evolution
Old 05-12-2004, 09:00 PM   #1
I'm trying to switch out my gears and my thrid member is like 40 years old and has never been off and pretty much rusted on so how can i get it off.
66burningrice is offline   Reply With Quote
Old 05-12-2004, 09:03 PM   #2
Zim
You want to **** me?
Zim's Avatar
not exactly sure what a third member is... but would air tools take care of it??
I like toys
Old 05-12-2004, 09:09 PM   #3
the third member is the gears that go into the pumkin and all the bolts are off I just cant get it out of the pumkin
Old 05-12-2004, 09:10 PM   #4
Zim
Zim's Avatar
oh, mabe hit it a bit with a blunt object to loosen it up? lots of wd40 too...
I like toys
Old 05-12-2004, 09:12 PM   #5
yeah i've been beating the hell out of it and it wont budge
Old 05-12-2004, 09:18 PM   #6
Zim
Zim's Avatar
lol no idea then... wait till fast64 gets on, he'd know more about it than i do.
I like toys
Old 05-12-2004, 09:20 PM   #7
alright thanks for the help newayz
Old 05-12-2004, 11:02 PM   #8
01mineralgrey6's Avatar
trying to pull the gears??? i know you gotta pull the axles to do that.... not sure what else
-Tony
'99 cobra 'vert
Old 05-12-2004, 11:22 PM   #9
Region: New Hampshire
Send a message via AIM to Smokedya95stang
Get a gear puller. That might do it.
-Charles
Smokedya95stang is offline   Reply With Quote
Old 05-12-2004, 11:22 PM   #10
Ps: post pics i have a 1966 mustang too man.
-Charles
Old 05-13-2004, 06:29 PM   #11
dont isntall gears your self if you have no training, formal training.... else you are just delaying the fact that pro will have to redo your screw up.... its not easy and should not be attempted by someone who doesnt know what they are doing you have to shim the rear and set the backlash correct or you will have horrible whinning and the gears will nto wear right.
Old 05-14-2004, 06:50 AM   #12
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I don't know if the diff is basicly the same in mine ('00), but after the back cover is off and the bolts on the C shaped retainers are off, I used a prybar to pop mine loose.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 05-15-2004, 05:51 PM   #13
it ends up there were some copper washes from the factory that locked the thrid memeber to the housing and i got it out and got my new gears in fine and there is no whining what so ever the car runs great thanks for all the help
Old 05-15-2004, 08:44 PM   #14
Zim
Zim's Avatar
good deal... hang around the site, itd be nice to get some more classic guys here
I like toys
« - | clutch play »
got some problems noslow5ohh 1979-1995 Mustang GT 0 06-05-2008 12:04 PM
Problems Once Again... MyStangStanks Pre-2005 V6 Mustang 3 11-20-2006 06:25 PM
a/c problems Warfire80 1996-2004 Mustang GT 6 11-29-2004 04:52 PM
More Problems Toxinz The Bar 4 05-01-2004 10:09 PM
Problems: Smokedya95stang ME Site Help & Announcements 0 03-06-2004 06:51 PM
03:59 AM
