Need Help with Rear End Problem on my 70 Mustang - Mustang Evolution
Old 11-28-2008, 05:07 PM   #1
I have problem that I need help with.
I have a 70 Mustang sportsroof that I am trying to bring back to life. I have it running, steering, shifting and stopping. The problem that I am having is in the rear end (somewhere).
I have only driven up and down the driveway. At the same spot when I back up there is a feel and sound that comes from the back end. It almost feels and sounds like something is binding up and then releasing. It is bad enough that I can actually feel it in the drivers seat. I had my two neighbors watch while I backed up and pulled forward. One of them thinks it is in the rear end. The other thinks it is in the rear, passenger side wheel (he thinks that the rear, passenger side wheel actually moved when it happens).
Here is some additional information:
1. Rear end is out of another model of Ford. The tag is "WDZ-8(or B?)1(or I?) 9EB 3L00 8 875A". So it is an 8" posi out of ? Fairlane?
2. The parking brake cables are not connected to anything (they are both hanging down).
3. When I apply the brakes and come to a stop the car rocks back and forth a little.
4. I raised the rear end up and turned the rear tires in both directions. They were hard to turn. And in certain spots (every 3rd full turn or so) they were very very hard to turn. Both tires turned together in the same direction. There was no play in the driver side tire. There however was about 1 1/2" of play in the passenger side tire. What I mean by that is when I turned the tire it turned about 1 1/2" before the axle engaged and the drive shaft turned. And when I turned the driver side tire the axle would turn and the drive shaft would turn immediately but the passenger side tire would not turn until the driver side tire had turned about 1 1/2".
5. The drive shaft and rear U-joint seem to be solid with no movement in /out, up / down or side / side.
6. I took the wheels off. The brake drums don't match. They have the same width and height dimensions but the profile is different. The hole in the passenger side drum that the axle hub sticks thru is also 5/16" bigger in diameter that the hub. So even though the lug holes are correct (correct pattern), the hub hole is not and the drum is loose.
7. I took the brake drums off. The brake components seem to all be there and installed correctly. The brake shoe adjusting device on the passenger side was not competely slid into the indented slot on the brake shoe. I just simply slid it back into position.
8. When I pulled on the end of each axle they did not move in / out or seem loose.
I think that is all I know. If there is something else that would help someone figure out the problem, just let me know.
Thanks.
blk66stang is offline   Reply With Quote
Old 11-28-2008, 06:13 PM   #2
Re: Need Help with Rear End Problem on my 70 Mustang
Based off of what you posted...I'd venture to say you have a bent axle. Especially with them binding up in certain areas. The bad part is might be something in the housing itself. I'd go ahead and pull the axles and check the bearings for play/looseness.
Old 11-30-2008, 03:56 PM   #3
hottcobra's Avatar
It does sound like u have a bent axle, but it also sounds like the you a problem with the locker also. thats just something that you have to tear down to know for sure. you really need to rebuild that rear end anyway. it's just an investment in time, cause you don't really know what u have and their's nothing worse than getting your car finished and get 1 weekend out of it and then have to tear the rear end apart
Old 12-03-2008, 02:51 PM   #4
The Darkside's Avatar
i also think it sounds like a bent axle. Thats just my 2 cents.
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
'05 Mustang Rear End Problems Terps04 General Mustang Discussion 1 08-04-2008 06:56 AM
1996 Mustang GT rear end gear ratio Buzz 1996-2004 Mustang GT 2 04-23-2006 07:19 PM
10:23 PM
