289 won't start - Mustang Evolution
Old 01-29-2009, 05:15 PM   #1
289 won't start
Hi I have a 1967 mustang coupe with a 289 C code engine. This winter I decided to detail the engine compartment so I pulled the engine out and painted it... But now its back in the car and WON'T START... I cheked timing witch is set 6 deg btdc when I crank it... The gas is comming to the carb and plugs are new. I cheked the compression: 153 psi on all cylinders and the fire is real strong on the plugs firing order is right. When I crank the engine it just backfire to the carb and won't start at all I even had a splash of gas comming out of the carb. Please help me i'm I NEED HELP thanks pascal
pascal1967 is offline   Reply With Quote
Old 01-29-2009, 05:59 PM   #2
hottcobra's Avatar
Re: 289 won't start
if it's backfiring through the carb. You've got dist. 180* out
Old 01-29-2009, 08:42 PM   #3
Re: 289 won't start
Thanks Hottcobra just lifted the dist and switched the shaft 180deg and it's strated like a new
Old 01-30-2009, 08:53 AM   #4
hottcobra's Avatar
Re: 289 won't start
no problem. glad I could help
Old 02-05-2009, 10:04 AM   #5
The Darkside's Avatar
Re: 289 won't start
wow hotcobra, you are the man! lol thats a one post fix! lol
American Muscle forever!
i bleed Race fuel!
http://www.youtube.com/watch?v=o_FjllgR5-Y
The Darkside is offline   Reply With Quote
12:04 AM
