weatherstrip vent window - Mustang Evolution
Old 02-15-2009, 04:36 PM   #1
DAC
I'am trying to replace the vent window weatherstrip on my 65,with little luck...All my diagrams are of little help.Can any one out there help?
DAC is offline   Reply With Quote
Old 02-23-2009, 05:28 PM   #2
Mil1ion's Avatar
Send a message via Yahoo to Mil1ion Send a message via Skype™ to Mil1ion
Re: weatherstrip vent window
which diagrams do you have ?
Mil1ion is offline   Reply With Quote
Old 02-24-2009, 09:54 AM   #3
Herbstang's Avatar
To replace the window seal, you first have to remove the vent window assembly from the door. After it is removed, the nut and spring on the bottom of the window has to be removed. Then remove the glass and frame from the vent assembly frame. Then gently remove the rubber off of the frame and install the new one after you replace the top vent bar seals. Reverse the window removal procedures to reinstall the glass and frame. The top vent bar seals requires a special tool to remove and replace the rivets you get with the replacement seal. You need to replace the top vent bar seal before reinstalling the new vent window rubber.
Old 02-24-2009, 05:49 PM   #4
Mil1ion's Avatar
Click for larger image
Side VEnt install Foxone General Mustang Discussion 8 09-26-2009 01:24 PM
No t-top weatherstrip OEM or after market ? my83 horse 1979-1995 Mustang GT 13 03-19-2008 01:40 AM
Air vent problem.Help! fordguy5.0 Pre-2005 V6 Mustang 2 12-03-2007 10:58 AM
Random Vent..Grrrr ChickStang02 The Bar 18 03-27-2007 04:20 PM
08:54 AM
