rewiring 65 fastback - Mustang Evolution
Old 02-17-2009, 08:11 PM   #1
I am in the process of rewiring my mustang and have almost completed the task. The only problem I am having is the gauges. When I turn on the key they peg out. I have changed the regulator on the back and still nothing. Help
denpsim is offline   Reply With Quote
Old 02-18-2009, 07:32 AM   #2
AllStangs's Avatar
Re: rewiring 65 fastback
Do all gauges peg out? Typically that's a voltage regulator problem, but you're already tried that. (Dumb question, but when you say regulator you're talking about the tiny silver one behind the instrument cluster, right? Not the larger one near the battery in the engine bay?)
The fuel gauge could spike if the wire was grounding somewhere along the line back to the sending unit in the tank. Maybe the other gauges are having the same issue.
Classic Mustangs Blog
AllStangs is offline   Reply With Quote
Old 02-18-2009, 08:59 AM   #3
sounds like the sender is going to the power by accident causing the needle to jump over~ hmm
Old 02-18-2009, 07:52 PM   #4
It is the small one on the back of the gauge cluster. went to O'rielys tonight to get a new one will no more tommorrow
Rewiring stock amps to new head unit? runvsofthisbull Pre-2005 V6 Mustang 9 02-04-2008 04:41 PM
Rewiring stock amps to new head unit? runvsofthisbull Mustang Audio & Video 2 01-08-2008 10:17 AM
rewiring lights fastang11 Pre-2005 V6 Mustang 2 02-10-2006 12:43 PM
10:13 PM
