Well Ford OFFICIALLY has to step it up..... - Mustang Evolution
Old 12-09-2004, 09:34 PM   #1
bluemustang's Avatar
a few damn notches.
What im about to show you guys is something that will require an extra pair of pants near by
I present the 2006 Z06 Corvette rool:
Here are the specs
0 -> 60 in 3.8 sec.
Top Speed 200 MPH
2,900 #'s
5.7 #'s/HP
Chassis & Suspension development by Pratt & Miller,
Aluminum Hydroformed frame produced by DANA
- 345/30x19 Rears
- 6 piston Front, 4 piston Rear Brake Calipers
- Cross Drilled (cast and camfered) Rotors (possibly Brembo)
Engine Development by KaTech
To be hand built by new HP Engine Plant
LS7 427ci/ 7.0L. 500HP/500 Ft Lbs (512 HP derated to 500HP)
- 2 OHV (3 OHV not necessary for target HP)
- Raced based CNC ported Aluminum Head with 70cc chambers
- 11.0:1 CR
- 46 mm (1.81") Titanium Intake valve
- 41 mm (1.61") Na filled Exhaust Valve
- 104.8 mm Bore (4.125") , 101.6 mm Stroke (4.0") Aluminum block
- Forgrd Crank
- Forged 6 bolt main Bearing Caps
- Titanium Rods
- Cast Aluminum Flat Top Pistons
- 0.591" Lift Cam (15 mm)
- Dry Sump
- 90 mm Throttle Body on Composite manifold
- Ram Air
Old 12-09-2004, 09:38 PM   #2
i would kill for that car
Old 12-09-2004, 09:56 PM   #3
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
I'd pimp it.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 12-09-2004, 10:02 PM   #4
97Stallion's Avatar
You know Ford already has the Ford GT, that's Ford's answer. Then you might say price. Do you think that crappy chevy is going to be cheap. I would say atleast 100 G's easy.
Living one day at a time!
Old 12-09-2004, 10:04 PM   #5
97Stallion's Avatar
Ford GT
Wheel Base (in): 106.7
Overall Length (in): 182.8
Overall Height at curb (in): 44.3
Overall Width (in): 76.9
Front Track (in): 63
Rear Track (in): 63.7
Weight Distribution (ft/rear): 43/57
Overall Shadow (sq ft): 96.8
Approach Angle (deg): 9.2
Departure Angle (deg): 14.0
Seating Capacity: 2
Leg Room (in): 44.6
Head Room (in): 35.4
Shoulder Room (in): 57.7
Hip Room: 57.8
Passenger Volume (cu ft): 52.8
Interior Volume Index(cu ft): 54.4
Engine Type: DOHC, 4 valves per cylinder, supercharged V-8
Engine Displacement (L): 5.4
Bore/Stroke (mm): 90.2x105.8
Displacement (cu in/cc): 330/5409
Compression Ratio (in/mm): 8.4:1
Material: Aluminum block
Horsepower @ RPM: 550@6,500
Torque @ RPM (lb ft): 500@3,750
Horsepower Specific Output (hp/liter): 101.9
Torque Specific Output (lb ft/liter): 92.6
Recommended Fuel: 91 octane (premium)
Fuel System: Sequential multi-port electronic fuel injection -(SEFI) with dual injectors per cylinder
Oil Capacity with Filter (quarts): 12
Usable Fuel Capacity (gal): 17.5
Type 6-speed manual
Gear Ratios 1 - 2.61
2 - 1.71
3 - 1.23
4 - 0.94
5 - 0.77
6 - 0.63
Reverse - 3.135
Final Drive Ratio 3.36:1
Gear Synchronization 1 - Triple
2 - Triple
3 - Triple
4 - Triple
5 - Double
6 - Double
Chassis/Steering/Brakes
Drivetrain Layout Mid-engine, Rear-wheel drive
Front Suspension Double Wishbone
Rear Suspension Double Wishbone
Steering Type Rack-and-Pinion
Steering Ratio 17:1
Turns Lock-to-Lock 2.7
Turning Circle (Curb-to-Curb) 40 ft.
Brake System Vacuum Power Assist
Front Brakes (in) 14.0
Rear Brakes (in) 13.2
ID:	4876   Click image for larger version
ID:	4878   Click image for larger version
Old 12-09-2004, 11:43 PM   #6
Not liking it. Too many styling cues from other cars...namely, it looks like a corv-iper. Not too keen on it. I will still with my little pony car and let the 50+ year olds baby thier mid life crisis vettes around. At least, that is what 95% of all vette owners I see are...either 50+ or a stripper. :pancake:
Old 12-10-2004, 12:46 AM   #7
I liek gramer
WhiteStang99's Avatar
id hit it.
Old 12-10-2004, 05:19 AM   #8
fast64's Avatar
isnt the 06/07 cobra supposed to be under $50k and a corvette killer? anyway, like i've said before, i dont like the new corvettes, they look like the unfortunate love child of a viper and a ferrari that was adopted by chevy.
GO BRAVES
Old 12-10-2004, 05:45 AM   #9
The the Z06 is around 60k not 120k like the GT
Sorry Chevy wins this round at least the Vette is a closer chance to actually own compared to the GT
Old 12-10-2004, 06:22 AM   #10
theglory's Avatar
I would love to have that car. I would take in a heartbeat. I think it looks awesome and plus, its got a 427 in it. Who wouldnt want that in your basement. I agree with bluemustang the vette will be about 60-70 g's not even close to 120 g's plus I think the vette looks way better than the gt. I'm not really all that crazy about the gt especially the interior it looks cheap to me. Ok I went and looked at the interior pic and its mainly the seats that look cheap. I'd still take the vette over the gt.
http://www.mustangevolution.com/foru...ine=1101229075
Just living out the blessings Gods given me, one mile at a time!
So many Struggles, So many Trials, So many reasons for me to Fall, But I have all Strength, And I have all Power, And I will Bury You!
theglory is offline   Reply With Quote
Old 12-10-2004, 07:20 AM   #11
Id take the GT over the vett. Chevy can't be original. I don't like the way it looks at all. I say chevey needs to quit copying and do a retro look ala the 70s stingrays.
Old 12-10-2004, 07:35 AM   #12
Danger Dude's Avatar
I like the Z06 Corvette. I like the body style. I like the 427 engine. I do see some similarities on the headlights with the Viper but most cars now ahve similar looking fronts. The interior is simply excellent. The Ford GT is a nice race car but for real world driving I would take the Vette.
Oh with Ford closing the SVT division the Cobra will not happen unless it is brought out by Saleen or Roush which will make it a very expensive mustang to own!!!
Old 12-10-2004, 08:43 AM   #13
theglory's Avatar
Well n8r from what I saw on tv they did an interview on the 05 stang and the c6 vette. Thats all they talked about was how the stang is retro, and how chevy went retro with the new vette. Giving it some cues from the older vettes.
Old 12-10-2004, 10:17 AM   #14
They haven't closed down SVT....yet. It is one of the ideas those morons are throwing around, but it is still open for business. They did shut down the Lightning division and put everyone over on the Cobra project. Like you said, rumor has it that they are thinking about having Cobras produced by Saleen though, which I think would suck. And I agree, the price would get retarded just like the Saleens are now.
My thoughts are, that if they do drop the SVT division, there are going to be a whole lot of not so happy customers that will end up jumping ship over to Chevy. Hell, there are already a lot of Cobra owners that are looking at trading in on the C6. Good for those wanting a used Cobra, but bad for Ford.
And to get back on topic, I still aint feeling the C6. It just doesn't appeal to me at all.
Old 12-10-2004, 12:29 PM   #15
97Stallion's Avatar
maybe the current Z06 is 60K, but I'm sure that 2006 one won't even be close to that price. Did you read the specs. Titianium this and titianium that, all aluminum block.
Old 12-10-2004, 12:54 PM   #16
In 69 the aluminum 427's came in the ZL-1 Camaro and ZL-1 Corvette The motor puts out an estimated 525hp.
Old 12-10-2004, 01:58 PM   #17
theglory's Avatar
The current z06 block is all aluminum. And its more around 55k, thats why I think this one will 60-70k probably closer to 70k.
Old 12-10-2004, 02:39 PM   #18
evilweirdo42's Avatar
id take it.
Originally Posted by SpectorV
You forget a stock mustang has the same ground clearence as a 4x4 f150...
evilweirdo42 is offline   Reply With Quote
Old 12-10-2004, 02:40 PM   #19
Suggested retail price is listed as 60-65k.
Id honestly take this z06 in a heartbeat who doesnt want that bad boy 427.
I dont like chevys minus the Bel Air but im telling you this vette right here is flat out nasty.
Cobra what?
As someone just mentioned people will be trading i their 03/04s for the C6 or Z06 and you know what im gonna be right behind them people picking up their cobra. Cause you know thos cobras are gonna go very decently low priced.
Old 12-10-2004, 02:45 PM   #20
theglory's Avatar
hey that would be nice.
Old 12-10-2004, 06:08 PM   #21
I don't like it at all
Old 12-10-2004, 06:09 PM   #22
00vertstang's Avatar
I take offense to that remark
I know that ricko36 and I are both over 50.
All I own is my stang
00vertstang is offline   Reply With Quote
Old 12-10-2004, 07:21 PM   #23
Well, there is always one in the crowd.
But the question is, do you only drive around at the speed limit (usually less) in your stang, or do you get on it once in a while? That is the key here.
Old 12-10-2004, 07:36 PM   #24
Back in my younger days I as known as lead foot willie
Old 12-11-2004, 11:56 AM   #25
Tbird232ci's Avatar
and ford is being original by making a modern clone of a car they built how many years ago?
it would be like ford taking a 65 stang, updating the suspension, adding an EFI 4.6, and calling it original...
Old 12-11-2004, 11:59 AM   #26
The 05 Gt is a mustang.. not a crossbreed between a viper, ferrari and little pieces of corvette here and there
The 05Gt is original. Ford Made the 1965 Mustang.
Chevy didnt make the Viper or Ferrari but you can see pieces of each car in the vette
Old 12-11-2004, 12:02 PM   #27
Tbird232ci's Avatar
and sadly, i find the 05 GT to be horrid looking
i was more refering to the ford GT rather than the 05 GT, and im glad the 05 GT is original because it looks like **** in my opinion, seems too playskool like
Old 12-11-2004, 12:33 PM   #28
05 Gt is fing sweet lol
Have you seen one in person?
Old 12-11-2004, 12:35 PM   #29
steedav6builder's Avatar
Send a message via AIM to steedav6builder
omg i would kill for the 05 GT it looks so badass. i didnt like it in pictures till i saw it then i loved it. the 05 GT is the definintion of american muscle
-Gary Pics of my car
'99 Electric Green Cobra, #2517 of 4040 Built on 5/12/99
'00 Lazer Red V6-Gone but not forgotten
Central Jersey Mustangs and Fords Member #4121
Mid -Atlantic Cobra Association Member #207
steedav6builder is offline   Reply With Quote
Old 12-11-2004, 01:13 PM   #30
ford has never really competed as far as speed goes with gm.... ford just out sales them eleventy billion to one... if gm started to sale more cars ford would get on the performance wagon more.
Old 12-11-2004, 10:51 PM   #31
Tbird232ci's Avatar
i saw one in person last week, and i personally think it looks fake, almost like it shouldnt be a real car, out of proportion almost
the next step upton7 General Mustang Discussion 4 03-29-2009 10:58 PM
Microsoft's first step... bullitt482 The Bar 17 07-10-2007 12:05 AM
what should be the next step? charkelly9 Pre-2005 V6 Mustang 13 09-22-2005 11:33 AM
got another step complete. whipster24 Pictures and Videos 6 04-09-2005 08:32 PM
w00t! one small step for me, one giant step for my car fast64 Mustang Audio & Video 5 06-02-2004 01:54 PM
03:24 AM
