Forgot to mention - Mustang Evolution
Old 05-17-2009, 11:40 PM   #1
upton7's Avatar
Forgot to mention
Besides my gt my dad gave me his 1976 pontiac firebird formula for my graduation present last year. It was both of my sisters first cars for about a couples months and the 2nd one that had it wrecked it into a guiewire for a telephone pole. (i was in it) It ****ed up the driver side fender and door. It's a 400 cid automatic Yellow with the black formula stripe on the bottom and the dual hood scoop. My question is how much is it worth. What all do i need to do to get it running. (been sitting for about 8 years) All known mechanica damage is a bend drag link or sumtin like that and maybe a tie rod
Old 05-18-2009, 08:37 AM   #2
bloodyspirit058's Avatar
Region: Oregon
Send a message via MSN to bloodyspirit058
Re: Forgot to mention
pics?
It's cheaper to be beat a viper than to lose in one.
1994 GT, stock gears, stock shifter, stock engine, stock rims (or knock offs).
Originally Posted by sti2gsxr
There was a case of the stuff stacked at the end of an aisle. Definately not cold or in the cooler. Also it was over $7 for the two bottles.
bloodyspirit058 is offline   Reply With Quote
Old 05-18-2009, 09:41 PM   #3
upton7's Avatar
it'll be a while b4 i can get pics i just want to know what needs to be done to a vehicle that has been sitting that long
Old 05-18-2009, 11:56 PM   #4
Region: Oregon
haven't really had that problem, but on other forums with other cars, the brakes were frozen closed, diffently make sure they are in working order, all the rubber gaskets will probably have started cracking, maybe not, but probably, check your belts... gas will probably be bad, or not very good... if its kinda low just fill it up, if it was full before being parked i would try to syphin some out (personaly i would do this, but it might not really be a problem) probably just change all the fluids just to be safe. make sure moving parts are free to move and solid parts are not...
i'm guessing it has a caburator, and from what i've heard they dont' like to sit, so you'll probably have fun with that (in shop class we have a metal container with all types of fuels and setitives in it, we put a rusted out lawnmower carberator in that and took a tooth brush to it a day or to later and it worked fine... i'm sure this is a little differnt, but somethin along those lines might help it get started.
i've mostly been assuming its been sitting outside, so ill ask, has it been in a garage for the 8 yrs or outside?
check all your rubber hoses for cracks... radiator hoses, vaccum lines, brake lines ect.
thats all i can really think of, sorry its all drawn out and randomly ordered. i just wrote down things as i thought of them and its passed my bed time
Old 05-19-2009, 12:10 AM   #5
upton7's Avatar
its been in a shed away from the wheater but it didn't have head or a/c or anything like that
Old 05-19-2009, 09:50 AM   #6
Check the tires as well, sometimes they will crack or rot from sitting for an extended time.
Old 05-19-2009, 05:44 PM   #7
Region: Oregon
^+1 also check the manufacture date, its debateable, but if the car had older tires on it, and than sat for 8 yrs, even if the tires look good and/or ok they might still be really bad...
Old 05-19-2009, 08:37 PM   #8
upton7's Avatar
oh the tires are ****ed. i need to know what i need to do to get the engine to turn over i can take care of everything else.
Old 05-19-2009, 09:03 PM   #9
Region: Oregon
well if the starter is turning the engine and its not firing i would check spark on all cylinders or just replace all the plugs and wires (which might be a good idea ne way) but also removing the carb and putting another one on, or cleaning and/or rebuilding the current one since i'm sure its not going to fuction correctly after sitting so long.
are you planning on keeping the car or selling it?
Old 05-19-2009, 11:51 PM   #10
upton7's Avatar
I will never sell that car in mine or anyone elses lifetime. No matter what it comes down to.
Old 05-20-2009, 07:08 AM   #11
Region: Oregon
good answer though i still want pics
keep us posted on your progress, have you tried turning it over? does it do anything?
Old 05-20-2009, 07:24 PM   #12
upton7's Avatar
there ain't no way the battery is charged and i don't want to run that old gas through the engine
Old 05-20-2009, 09:41 PM   #13
Region: Oregon
very true on both, let us know when you get a new battery and change the gas, very interested to see how it goes.
Old 05-21-2009, 03:34 PM   #14
upton7's Avatar
you got it dog
did i mention? SimplyOrange The Bar 8 02-07-2009 08:35 AM
Kid forgot he didnt have a doorknob KyleUSAF The Bar 8 07-15-2006 05:26 PM
Forgot to ask? Any hot girls in here now? 03redfire cobra The Bar 34 11-03-2005 07:37 PM
Mention Whether V8 Or V6 Smokedya95stang Pre-2005 V6 Mustang 6 07-13-2004 10:22 AM
10:24 AM
