2001 Sport Trac wheel stud - Mustang Evolution
Old 07-07-2009, 04:08 AM   #1
Greywolf's Avatar
Region: Nevada
Angry 2001 Sport Trac wheel stud
Saturday afternoon my wife calls me and she's broken down on the side of the road. I work the Grave shift at one of the Vegas resorts and it's 2pm, basically right in the middle of my sleeping time. Luckily for me Vegas has a complimentary roadside service van that drives around all day helping people on the free way. He helps her make sure all is good and she limps it home while I sleep soundly.
Fast forward to today. I've got the car on the jackstands, remove the wheel, brake caliper, caliper mounts, etc. All of the studs are starting to rust a bit so I figure I'll remove them and replace them all. Or so I thought. I tried for an hour and a half and the damned things wouldn't come off. So I called the service department at the Ford dealer I used to work for and got ahold of one of my friends. He's looking through his system and he can't even find a parts number for the studs. There are no studs! At least not seperately. All he's showing is a wheel hub for $389. Now after some work I yank out the bearings and get the rotor off and bingo. I don't need to hub but aparently they attached all the frickin studs to the rotor and now I have to pay for a whole new rotor. What happened to the days of pounding it out, buying a $1.50 part and moving on. I love Fords, they're usually pretty easy to work on but whoever designed this little assembly had his head way too far up his ***. Needs to be strung up by his balls and left to die.
Ok, I'm off the soap box. Continue with your day...
2007 V6 Mustang w/ Pony Package. Performance Mods - 2.25 custom aluminum catback exhaust with a Magnaflow muffler, AirRaid cold air intake, drilled and slotted rotor's front and rear, SCT Programmer, Ford Racing Tlok, Motiv 4:10 gears, LFP underdrive pulley
Greywolf is offline   Reply With Quote
Old 07-07-2009, 04:33 AM   #2
Re: 2001 Sport Trac wheel stud
Obviously they were redesigned to combat the exploding tires!
ThaWill is offline   Reply With Quote
Old 07-07-2009, 04:57 AM   #3
I was going to tell you they were probably one piece....but I see you figured that out lol.
Old 07-07-2009, 07:23 AM   #4
jimmy_beaner's Avatar
Region: Iowa
Yeah, my Mustang GT and F150 both have removable studs. You may consider trying to see if you can "retro fit" a new rotor design with removable studs in.
Old 07-07-2009, 07:39 AM   #5
mine thankfully pop right out, just how they design some parts ~ some cars are like that
Old 07-07-2009, 07:48 AM   #6
Greywolf's Avatar
Region: Nevada
It's just one of those REALLY annoying features. I don't think i would have even been that annoyed if I had known ahead of time they were gonna work that in there as an added feature that eats away at the wallet. I also probably would have been so pissed if I hadn't had to yank away at some seriously too tight bolts with a shoulder that was cut open/operated on 3 days ago. My gawd that hurt like nothing else. Oh well, leasson learned.
Trac-Loc wheel hop stangaroo Pre-2005 V6 Mustang 8 11-30-2009 02:04 AM
abs and trac control light. powerstroker Pre-2005 V6 Mustang 3 05-21-2009 12:56 PM
3.90 gears and a trac lock Rick0636 Mustang Parts for Sale and Wanted 0 09-01-2005 07:35 PM
Changing to a 8.8 trac-loc Sharpie Pre-2005 V6 Mustang 19 08-20-2004 07:09 PM
06:45 AM
