7.0L Mod Motor? - Mustang Evolution
Old 12-11-2009, 01:14 PM   #1
SVTCOBRA's Avatar
7.0L Mod Motor?
Ive been trying to do research on the engine in the saleen S7. Ive read that the 7.0L engine is used off on a Ford block but wich ford block is used? Is is a mod motor? I just cant seem to find the answer to my questions. So if anyone one knows please tell or point me in the right direction.
Thanks.
SVTCOBRA is offline   Reply With Quote
Old 12-11-2009, 02:19 PM   #2
Re: 7.0L Mod Motor?
I think its a big block 427 is it not? Not a modular engine~
Old 12-11-2009, 09:11 PM   #3
OsirisGuy's Avatar
Re: 7.0L Mod Motor?
From wikipedia and Saleen, Inc's website (based on the 2006 model);
The 2000-2004 S7 featured a 7.0L (427.6ci, 7008cc) N/A all aluminium OHV (2-Valve) V8. With a compression ratio of 10:1 the car made 550 HP at 6400 RPM and 525 ft-lbs of torque at 4000 RPM. The car redlines at 6500 RPM. Bore X Stroke is 4.125 x 4.00 in. (104.8 x 101.6 mm).
0-60: ~3.9 seconds
0-100: ~8.1 seconds
1/4 mile: ~11.75 @ 126 MPH (~203 km/h)
Top Speed: 210 MPH (340 km/h)
*Numbers are estimates.
2005-2006 saw the twin turbo set up with a pair of Garrett Turbochargers which bumped the horsepower to 750 HP at 6300 RPM and 700 ft-lbs of torque at the 4800 RPM line. This was at 6 psi of boost.
0-60: 2.8 seconds
0-100: 5.9 seconds
0-200: 27 seconds
1/4 mile: 10.5 seconds
Top Speed: 248 MPH (399 km/h)
In 2006 the S7 got another bump in HP to an even 1000 HP, a 33% increase. Saleen claims a top speed of 240 MPH (390 km/h) but rumors of 260 MPH (420 km/h) are reported. 2006 also has a reported compression ratio of 11:1 and forged aluminium pistons. Camshaft and connecting rods are 4340 Forged Billet Steel. All aluminium CNC machined heads, Stainless steel with titanium retainer Valves; Intake: 2.125 in. (54.0 mm); Exhaust: 1.625 in. (41.3 mm) with Beryllium exhaust seats. Solid lifter/roller rocker valve train. 42 lb/hr fuel injectors running on 91 Octane from a 19 gallon tank. 12.6 qt High Vacuum Dry Sump oil system with an aluminium oil tank.
The Saleen S7R is "the most winning Supercar based" ever produced, which is a race modified standard, naturally aspirated S7.
A manual 6-Speed transaxle with full synchromesh, a 4-plate clutch, and a limited slip differential completes the drivetrain.
Gear ratios for 2000-2004.
1st Gear: 2.46:1
2nd: 2.06
3rd: 1.47
4th: 1.18
5th: 0.958
6th: 0.74
Final Drive Ratio: 3.22:1
Gear ratios for 2005-2007 changed with 1st gear and the Final Drive Ratio being steeper. All other gears dropped in ratio.
1st Gear: 2.86:1
2nd: 1.61
3rd: 1.14
4th: 0.96
5th: 0.81
6th: 0.64
Final Drive Ratio: 3.70:1
*Model differences only account for what's indicated, i.e., not any exterior or interior or otherwise mentioned modifications or changes.
From Modern Racer
"The S7 7.0L motor is based on the Ford all-so-common workhorse but it is all aluminium... bigger displacement and shorter overall length."
So I am going to say "no" and the Saleen S7's motor is not from any regular Ford truck, but is a specially built (modified) motor based on those motors. It is a OHV design so I am going to say it's a pushrod(?), so therefore it is not a Modular motor.
Hope that helps answer some questions.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 12-12-2009, 10:23 PM   #4
SVTCOBRA's Avatar
Re: 7.0L Mod Motor?
That helps thanks. Is there even a modular 7.0L V8?
Old 12-13-2009, 02:15 AM   #5
OsirisGuy's Avatar
Re: 7.0L Mod Motor?
One of the coolest things about the S7 is that theoretically it's aerodynamics are so good that the down force it produces allows the car to be driven upside down and still stick to the tarmac at just over some 100+ MPH (want to say closer to ~150 MPH)
Ford is planning on letting out a 6.2 (or was it 6.4?)L engine, under the Boss[/Hurricane] name. The engine is designed to be further Bored to one's liking and specification. Ford is adding this engine as a late option for the SVT F150 Raptor and to replace the current engines in their trucks (i.e., the Triton V10)
This seems to be the only thing close to a 7.0L Modular motor, except:
The 427 "Cammer" Engine, Ford's answer to Chrysler's Hemi.
That's at least the earliest (and only) info I found on a 7.0L Modular motor.
OsirisGuy is right
2002 Mustang GT
Old 12-13-2009, 08:46 AM   #6
SVTCOBRA's Avatar
Re: 7.0L Mod Motor?
Yeah I knew about the SOHC 427s in the 66 Fairlane but there is no way in hell I can even get that.
Old 12-15-2009, 02:08 AM   #7
Re: 7.0L Mod Motor?
The biggest production modular motor is indeed the 6.2 featured in the Raptor, but that motor is far too large to fit in a Mustang chassis without alot of work. There was a prototype modular 2 valve V10 Ford played with but like all of their things, it never seen production.
96 GT- Who knows what's in it.
Old 01-23-2010, 12:44 AM   #8
DEG
Re: 7.0L Mod Motor?
0-60: ~3.9 seconds
0-100: ~8.1 seconds
0-60: 2.8 seconds
0-100: 5.9 seconds
0-200: 27 seconds
1st Gear: 2.46:1
2nd: 2.06
3rd: 1.47
4th: 1.18
5th: 0.958
6th: 0.74
1st Gear: 2.86:1
2nd: 1.61
3rd: 1.14
4th: 0.96
5th: 0.81
6th: 0.64
From Modern Racer
wow
DEG is offline   Reply With Quote
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
What motor.. bullitt482 General Car Discussion 55 02-23-2007 03:51 AM
What motor..... bullitt482 General Car Discussion 9 02-16-2007 04:44 PM
New Motor GT-Eater Pre-2005 V6 Mustang 30 07-18-2005 12:01 AM
Motor coolstang Pre-2005 V6 Mustang 5 01-21-2005 09:19 AM
10:39 PM
