Anyone mess around with gm motors? - Mustang Evolution
Old 02-27-2010, 05:52 PM   #1
upton7's Avatar
I have tried multiple silverado and sierra forums and can not get an answer so I thought I would just go for it.
I got an 87 silverado it had stock a 305 blew it up. Replaced the 87 305 with an 84 350. The 87 motor was fuel injected. The 84 came out of a carbed sierra. The guy used the carb heads and got the intake manifold to somewhat seal on the carb heads. The 84 is old and I ended up paying 50 bucks for a 1970 350. It has been bored .030 over hot tanked and getting new gaskets pistons camshaft (rv) and bearings. When I get the short block built I want to have the heads rebuilt. I don't want to buy an extra set of fuel injected heads. Does anyone know of an intake manifold that will go from carb heads to a fuel injection throttle body?
Old 02-27-2010, 06:22 PM   #2
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: Anyone mess around with gm motors?
The problem that you're running into probably has to do with the changed intake bolt angles in the later SBCs versus the old style. Holley (and there might be others, too) makes a TBI to square-bore adapter that lets you put a TBI unit on top of any square bore intake. I don't know if there are any "made for TBI" intakes with the old bolt angles.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 02-27-2010, 06:27 PM   #3
MarkuzLS1's Avatar
Holley Performance Products TBI Adapter*17-41 - That's the one for spread-bore.
Holley Performance Products TBI Adapter*17-45 - That's the one for square-bore.
Then you can just run any old carbureted intake manifold.
I like turtles.
Old 02-27-2010, 06:32 PM   #4
upton7's Avatar
basically an adapter plate?
Old 02-27-2010, 09:09 PM   #5
MarkuzLS1's Avatar
Exactly. You mount a square (or spread) bore intake to the heads, mount the plate to the intake, and then mount the throttle body to the plate. Any old random dual plane intake should work just fine. I had good luck with a Performer RPM on my old 3rd generation Camaro.
I like turtles.
Don't mess with this old guy Brent The Bar 23 05-25-2010 03:12 PM
? about roller motors Z-EATER 1979-1995 Mustang GT 9 10-04-2007 11:27 AM
Anyone Mess With Second Life? Brent The Bar 16 05-31-2007 04:09 PM
Why You Never Mess With The New Kid bluemustang Pictures and Videos 3 04-06-2007 02:02 PM
What a Vtec mess. Seph Pictures and Videos 14 10-12-2006 02:16 PM
02:26 AM
