Need help with a fan motor!!!!!!! - Mustang Evolution
Old 03-01-2010, 11:08 AM   #1
outlawfrog's Avatar
Ok, so I just replaced the radiator fan motor on the wifey's car( 2000 Hyundai Elantra) . It still won't cut on when it should. The ONLY time it will cut on, is when I turn on the A/C....at that point, BOTH fans cut on. WTF is going on here? Any Ideas? Possibly the temp sender? But if the temp sender was bad, wouldn't the temp gauge not work correctly?
1996 GT, 5-speed, Moonlight Blue, Opal Gray leather, Flowmaster Cat-Back exhaust (Delta 40 series), BBK cold air intake & 75mm TBI, Super Chips programmer.
Originally Posted by 67mustang97 View Post
outlawfrog is probably right
Originally Posted by outlawfrog View Post
I might pull an "osirisguy", and make that my new sig quote!
outlawfrog is offline   Reply With Quote
Old 03-01-2010, 02:04 PM   #2
Re: Need help with a fan motor!!!!!!!
I had this SAME problem with my Sunfire. We eventually had to hook it up to a switch because we replaced the motor, and all that. We never did figure out what happened before it got totalled. Wish I was more help to you. ):
vintagel0verr is offline   Reply With Quote
Old 03-01-2010, 02:12 PM   #3
check the power wire make sure you don thave the wires messed up (not that you could if its a plug but who knows what they have changed)
Old 03-01-2010, 02:20 PM   #4
outlawfrog's Avatar
Doubt that's the prob.....it DOES run....but only when I turn on the A/C. Gonna take it to the shop this afternoon or in the morn to have the cat checked, si I'll get him to look at that too, I guess.
Old 03-01-2010, 10:11 PM   #5
Blogger
99ford's Avatar
I had that problem with my last car. I can't remember what it was though.. As I re-call at the same point in time, I had the hoses re-placed and a new water pump put in.
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
Sup mustang fan supersnake09 New Member Introductions & Greetings 13 03-27-2009 11:25 AM
Anyone here a fan of.... 1234 The Bar 17 01-07-2009 01:55 PM
WANTED: 1996 Fan Motor Checkmate Mustang Parts for Sale and Wanted 6 12-20-2005 10:54 PM
As much as I'm not a Honda fan... wiarumas The Bar 13 04-21-2005 06:41 PM
12:36 AM
