Burping the cooling system? - Mustang Evolution
Old 09-06-2006, 09:42 PM   #1
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
I may have to change out a radiator for someone and I always hear about people "burping" the system. Is this just to get unwanted air out or something? Anyone know how necessary it is or how it's done?
thanks for any info.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 09-06-2006, 09:51 PM   #2
MonteCitan's Avatar
Re: Burping the cooling system?
some vehicles have bleeder screws (GMs.. mostly).. most vehicles don't need too much..
for my stang(s) I loosen up one of the highest coolant lines (usually a TB line) then run the car til coolant starts coming out of line... hook line up and keep refilling the overflow til it gets to mark.. (or in case of the non-degas bottle style IE older stangs.. fill radiator directly...)then wait for tstat to open, refill again, close cap, check level, then check for leaks.. should be good from there
hope I didn't confuse you..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 09-06-2006, 09:55 PM   #3
DarkShadow's Avatar
Send a message via AIM to DarkShadow
It removes air from your cooling system, and yes it is necessary. You don't want excess air pressure causing improper coolant flow.
You can burp it by opening it up at the highest point in the system. Luckily ours is easy to get to. It is the largish bolt that is in front of the intake manifold and above the water pump with black tubes leading up to it. Just open it up and let coolant start coming out, close it back and refill from your cap. It will relieve pressure, if any, and cause less of a air pocket. There will still be some air obviously, but it will be less pressure is the key.
DarkShadow is offline   Reply With Quote
cooling system flush - Help!!!- 00stang3.8 Pre-2005 V6 Mustang 2 11-11-2007 11:10 PM
Need help with cooling system Dman Pre-2005 V6 Mustang 5 06-16-2007 10:35 PM
cooling 9899musl 1996-2004 Mustang GT 0 03-14-2006 05:24 PM
Cooling issues lightning 1996-2004 Mustang GT 5 10-12-2005 10:12 AM
My Cooling System 04MonteSS The Bar 12 07-30-2005 03:50 PM
10:32 PM
