Name of Tool Needed - Mustang Evolution
Old 04-16-2007, 04:07 PM   #1
bluemustang's Avatar
Name of Tool Needed
So uh I tried googling this but it just doesnt look right from what I saw
BUT my hatchback had crossthreaded threads and cant put the stock bolts back in.
Whats the tool name that rethreads the threads so I can put new one ins and I can have a fox with a bolted down hatch again.
Links or anything would be great too.
Thanks you bastards :smoke:
Old 04-16-2007, 04:11 PM   #2
MonteCitan's Avatar
Re: Name of Tool Needed
Tap (for the holes) Dies (for the bolts...)
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-16-2007, 04:12 PM   #3
MonteCitan's Avatar
Sears.com :pnoid:
Old 04-16-2007, 04:22 PM   #4
bullitt482's Avatar
A keg tap? oh wait... that's for something else....
01 Bullitt
Old 04-16-2007, 05:05 PM   #5
Scut95's Avatar
Tap and die sets get really expensive but are definately worth the money...they save a lot of time and hassle.
Old 04-16-2007, 05:33 PM   #6
helicoil kit or how ever you spell it?
Old 04-16-2007, 06:48 PM   #7
Brent.
Old 04-16-2007, 07:09 PM   #8
uh im so lost i tried looking for the helicoil kit and they have so many variables of them.
I just trying to find one to correct the old 10 mm hole.
what should I get to fix that?
Old 04-16-2007, 08:29 PM   #9
you need to know what type of thread pattern it is.
Old 04-16-2007, 10:38 PM   #10
if its a tap and die kit you are looking for, go to harbor freight, I picked up a decent set for real cheap.
Old 04-17-2007, 04:14 AM   #11
If your thread are stripped badly then you probably have to open up the holes and put threads in it for a bigger bolt. Or like Spector said already you may be able to use a helicoil which will also require you to drip a bigger and run new threads in it to screw in the helicoil. You may be able to get by with just running a tap throw the hole to straiten out the threads but IDK I'd have to see it. BTW make tap and if you drill it bigger make sure you use the right size drill for want ever sized thread you run.
I don't know what size threads your dealing with but here is a chart giving you the thread size and you drill your suppose to use.
Tap Drill Size Chart
JROC is offline   Reply With Quote
Old 04-17-2007, 11:49 AM   #12
well I can get the bolt half way in so I know the thread gets crossthreaded halfway in.
Think it be better to straighten the threads out?
never done this before so i feel like such a noob
Old 04-17-2007, 12:00 PM   #13
MonteCitan's Avatar
if you can start threading something, and the threads aren't completely stripped out, just tap it... the tap/die set will come with a thread indicator... match it up to the bolt to get the proper size... then run the tap in it'll fix up the threads -- the threads on the bolt are all okay, right?
Old 04-25-2007, 02:52 PM   #14
Just wanted to show you guys what im working with when I say my bolts are messed up, should i just clean up the threads?
Heres the spot without the bolts
The Bolts themselves
How The Bolts sit inside - Notice how the outside bolts are the one that cant go all the way through
(left side of hatch)
(right side of hatch)
Old 04-25-2007, 03:57 PM   #15
Fishers Stang's Avatar
mm just tap them, but lokin at the pics maybe thats how they are?
Charles
Old 04-25-2007, 04:28 PM   #16
yeah I been advise to just retap them, and their supuse to be flush like the inner bolts
Im gonna be buying new bolts ontop of new weatherstriping, hatch latch, hatch striker. That biotch better be fixed like no other
Ford First To Use Noise Identification Tool Software OsirisGuy General Car Discussion 2 11-03-2009 09:12 AM
Local GT500 Owner = Tool PureVenom The Bar 25 10-02-2007 08:27 PM
Tool Rocked!! bluemustang The Bar 1 10-06-2006 04:29 PM
this guy is a tool STEVE The Bar 17 03-25-2005 05:45 PM
05:06 PM
