Seafoam advice... - Mustang Evolution
Old 07-06-2007, 01:23 PM   #1
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Seafoam advice...
I'm going to be doing a Seafoam tune up on the car here shortly and I need some time frame and concentration advice:
I'm going to start out by putting it in my oil. I was planning on putting a half a bottle in for about 500 miles or less probably before I change the oil and filter.
This sound good? Too long, too short, too much, too little?
Then I was going to put a whole bottle into my intake and let it work out?
Would the line going to the brake booster feed all cylinders?
Again, too much, too little?
Then the other half a bottle into my gas after this.
Basically, I'm going to be doing a good tune up on the car because it pings from time to time, so I think I have some build up going on, and I'm going to be taking it on vacation with me in August. This will be my first time using Seafoam myself.
DarkShadow is offline   Reply With Quote
Old 07-06-2007, 01:29 PM   #2
Herbstang's Avatar
Re: Seafoam advice...
Might want to read this LS1TECH - How To Seafoam Your Car
Old 07-06-2007, 01:35 PM   #3
I've heard not to put it in your oil...
Without looking at the link above...this is what I have heard to do:
Run some through your gas.
Run some through your engine.
Change your oil
Done.
Old 07-06-2007, 01:37 PM   #4
You can put it into your oil. I put it into my oil, gas and through the brake booster.
Old 07-06-2007, 01:38 PM   #5
I know you can...I've just heard not to.
Old 07-06-2007, 01:44 PM   #6
My dad was told by a good mechanic friend of ours that it was perfectly fine to put into the oil. Especially good if you are burning oil.
Old 07-06-2007, 01:44 PM   #7
Herbstang's Avatar
Why Not ?? it's 100% pure petroleum.
Old 07-06-2007, 01:48 PM   #8
Don't know...just blurting out the ever accurate information I have procured off the interweb...it's on the net...it must be true...
Which is quite the dilemma...because now it is on the net that it is safe to use...so...both are true.
Old 07-06-2007, 03:32 PM   #9
DarkShadow's Avatar
So the brake booster line does feed the entire top end? Because a lot of places recommend using PCV lines, but mine are sort of difficult to use now...
Old 07-06-2007, 03:41 PM   #10
DarkShadow's Avatar
Thanks for that link Herb, answered most of my questions. I guessed pretty good with 2 cans.
Old 07-06-2007, 04:08 PM   #11
Thomas91169's Avatar
some people put about 10-20% of the can into the oil, another 10% in their fuel, and after certain mileage run 50% of the remainder through the motor, then the rest about a week later.
me? i just run around half the can through the motor and call it a day.
-Thomas-
Old 07-06-2007, 08:26 PM   #12
I'm with thomas, too much work for the other. I run about half a can through the car and call it done.
Also, I use the brake booster, even when I had true duals it came out both sides so I figured that's enough proof it goes through the whole engine.
Old 07-06-2007, 08:50 PM   #13
Unless you have a crossover...then it could just be merging at the cross.
Old 07-06-2007, 09:07 PM   #14
DarkShadow's Avatar
Scew all that with putting some in later. I'm just going to put it in the oil, booster, and tank once.
Old 07-06-2007, 09:18 PM   #15
That was before my x-pipe.
True duals (no crossover at all) it came out both sides.
Old 07-06-2007, 09:55 PM   #16
KyleUSAF's Avatar
Send a message via AIM to KyleUSAF Send a message via MSN to KyleUSAF
i did like half a bottle through the pcv. It smoked like mad, but if i remember correctly, it only came out one side..and i have true duals :chin:
Originally Posted by Darkshadow
I could say nothing for my complete awe. He then. confidantly, purchased the gallon.
KyleUSAF is offline   Reply With Quote
Old 07-06-2007, 10:17 PM   #17
DarkShadow's Avatar
Yeah, that would be true of the PCV from what I've read since that would only service that side of the motor.
Old 07-06-2007, 11:59 PM   #18
timpryor's Avatar
i just throw a full can through my PVC valve let her sit and start her up and watch my neighbors get pissed off
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 07-07-2007, 10:24 AM   #19
I seafoamed brent's mom last night...
Old 07-07-2007, 12:48 PM   #20
That took a long time to come up.
Then again...I'm sure that what Brent's mom said last night too...
Old 07-09-2007, 09:07 PM   #21
DarkShadow's Avatar
Well operation Seafoam went down tonight. I had already put it in the oil and then tonight I put it in the intake and changed oil afterwards. It did a LOT of smoking just while we were putting it in, then it did a lot more afterwards. It took about 3 WOT's and then a little more driving to get it cleaned out. Car runs smoother but it always does right after an oil change so :dunno:
Old 07-09-2007, 09:49 PM   #22
FattyMcFaterson's Avatar
Send a message via AIM to FattyMcFaterson
I threw a whole bottle in my truck tonight too. It smoked for about 10 seconds before it burned off. :dunno:
Triton V-10 for the win.
Oh Snap! Baconz!
FattyMcFaterson is offline   Reply With Quote
Old 07-10-2007, 08:39 AM   #23
Herbstang's Avatar
I put 1/2 bottle in the gas and intake and I smoked for awhile afterwards
Old 07-10-2007, 08:46 AM   #24
I need to do that, wont putting it in the gas tank clean off the cylinders and valves on the intake.
Old 07-10-2007, 09:44 AM   #25
rydog's Avatar
Send a message via MSN to rydog
Putting it in the brake booster will do that to putting it in the gas tank cleans your injectors, fuel lines etc.
i used about 3/4 of a bottle through my motor and the rest in my gas tank let it sit for about 30min then started it up and ran it then changed the oil
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 07-19-2007, 09:12 PM   #26
DarkShadow's Avatar
So this thread is semi old but I had to say something else.
When I first put the Seafoam in the oil, and then in the intake, I did notice a good bit of difference, but now that it has been a while, and I now have it in the gas tank, all I can say is wow. I knew the car wasn't running as good as it had before, but I had no idea. Runs absolutely outstanding now all througout the rpm range of ALL gears. Just great, even if you dont have a whole lot of miles, I would still do this "mod".
Old 07-09-2008, 05:23 PM   #27
Foxone's Avatar
Ok, Im convinced, I need to replace plugs anyway, sounds like a good time to do it. I picked up an 04 3.8, and the guy who owned it was 85, probably bumbled around town building up all kinds of carbon.
Foxone is offline   Reply With Quote
Old 07-09-2008, 06:19 PM   #28
when would be a good time to seamfoam your car for the first time. mine has about 31,000 miles on it as a 2005...should i have already done it, or do u think it needs it yet?
girlandherstang is offline   Reply With Quote
Old 07-09-2008, 11:18 PM   #29
1234's Avatar
Go ahead and do it it cant hurt. Some do it every oil chage some every other, and some once a year, and so on. Its all personal preferance. Just one more way to keep your motor clean.
Old 07-10-2008, 12:29 AM   #30
remember to change plugs after seafoaming. Loose carbon deposits will foul out plugs.
Im doing 80% through the intake on the cobra, 20% through the fuel tank, then gonna change oil and plugs, all filters, etc. Anyone have some good places to pull vacuum on a 03/04 Cobra? Im sure i could figure it out, its just easier if someone tells me!
-Thomas-
Seafoam 96 mustang 96Mustang0250 Pre-2005 V6 Mustang 8 02-14-2010 01:59 PM
whats Seafoam??? yoshiStang19 Pre-2005 V6 Mustang 12 08-27-2009 01:30 AM
Finally used the seafoam Herbstang General Car Discussion 12 04-10-2008 12:31 AM
seafoam or something else.. white 98 gt 1996-2004 Mustang GT 1 07-19-2006 11:51 PM
04:23 PM
