Only runs when choked. - Mustang Evolution
Old 10-22-2010, 09:21 PM   #1
upton7's Avatar
I finally got around to working on my 1980 honda cx500 tonight. I took out the air filter and somehow it was filled with carpet. I charged the battery drained out the gasoline and it came out of the valve or petcock or whatever you call it very smoothly. I started it and it died I choked it gave it some gas up around 3000 rpm. It will idle for a while on choke but as soon as i turn the choke off and keep reving it up it makes a big crack out of the tailpipe then dies. But will start up again on choke. The way I see it the air was already choked when it was filled with carpet I took it out and ran it without the filter and still had to much air since I had to choke it which means it isn't getting much fuel so do I just need a carb cleaning?
Old 10-22-2010, 10:53 PM   #2
Re: Only runs when choked.
Most likely your idle jet is stopped up. Had the same problem with the 125 Honda I had, cleaned the carb real good and used torch tip files to clean the jets and adjusted it a little when I put it back together and it ran fine.
Straublittleman is offline   Reply With Quote
Old 10-22-2010, 11:36 PM   #3
upton7's Avatar
Never cleaned a carb before can you just put everything back the way it was when you take it apart or does the float or anything need reset.
Old 10-23-2010, 10:24 AM   #4
As long as you don't bend the float you don't have to reset anything. It isn't hard to take it apart just make sure you put everything back the way it was. and don't use comprest air through the fuel line with the float and needle valve out because you will blow out the seat for the needle valve on some carbs.
V-12 engine made of paper that actually runs! Scut95 The Bar 7 06-12-2008 06:11 AM
GT500 runs 9s.. MonteCitan Pictures and Videos 12 11-21-2006 03:20 PM
Engine runs, but hesitate/misfire jaynez31 Pre-2005 V6 Mustang 11 01-17-2006 05:30 PM
03 5spd runs 14.47@90 w/ bolt ons??? BrooksPS Pre-2005 V6 Mustang 13 03-09-2004 08:10 PM
After 3 weeks it runs. slow232 The Bar 13 08-17-2003 06:10 PM
08:40 AM
