Noob Question.... - Mustang Evolution
Old 12-26-2010, 08:25 PM   #1
MC770's Avatar
Noob Question....
Are sunpro gauges any good?
Or is it better to go with pro comp?
Sorry if it's a noob question never done gauges before
MC770 is offline   Reply With Quote
Old 12-27-2010, 12:06 AM   #2
Re: Noob Question....
I like sunpro. Don't see anything wrong with them but some people like fancier gauges. Or you can go with autometer wich are great gauges. If you can get the electronic gauges that way you don't have a oil pressure line running inside your car that over time could spring a leak and spay oil all over your carpet. Ben there done that.
Straublittleman is offline   Reply With Quote
Old 12-27-2010, 07:17 AM   #3
1234's Avatar
The only difference I found was the quality of the gauge.
Old 12-27-2010, 11:11 PM   #4
I speak for autometer cause that is what i have those in my car and they work great no problems at all and I have had them for better part of a year
Faststang0485 is offline   Reply With Quote
Old 12-28-2010, 08:08 AM   #5
1234's Avatar
I ran my Autometer Carbon gauges for around 2.5 years. Never had one problem.
Old 12-28-2010, 09:12 AM   #6
MC770's Avatar
So an electrical oil pressure gauge is better than the mechanical ones. If so how hard is it to set up one of the electrical gauges?
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
Old 12-28-2010, 12:17 PM   #7
I would go with autometer or the like if you want accurate data
Old 12-28-2010, 01:51 PM   #8
91GTstroked's Avatar
I've heard great things about speedhut gauges but there spendy! I personally like the revolution models, and you can customize them how you want.
Gauges, Custom Gauges, Tachometers, Speedometers, Shift Light, Pod
2003 REDFIRE SVT COBRA
455rwhp/480tq
91GTstroked is offline   Reply With Quote
Old 12-28-2010, 05:17 PM   #9
MC770's Avatar
Those are some pircey gauges lol. I think I might just get procomp gauges...
Old 12-28-2010, 09:25 PM   #10
Yes most aftermarket electrical gauges are accurate. To hook them up you have a sending unit that screws into place of your factory one and you run one wire to it from the gauge. Some gauges take two wires on the sending unit but one of the wires would be ground and you wouldn't need to run it inside the car just to any ground surface or wire. The gauge itself would have a wire to sending unit, ground, hot to ignition, and light wire if equipped. They're very easy to hook up and most come with very good instructions.
Old 12-28-2010, 09:31 PM   #11
MC770's Avatar
So for a water temp sensor it would take the place of the coolant temp sensor in theory, and tell you the temp. My temp sensor is not giving accurate readings and we already replaced it once.
Old 12-28-2010, 09:45 PM   #12
Yes, I'm running both my factory gauge and aftermarket mechanical temp gauge on my 94. I will be putting an electrical gauge on later when I have the money to spend on one. But I'm running a a/f ratio gauge, oil, and fuel pressure gauge that are electrical.
Old 12-28-2010, 09:58 PM   #13
MC770's Avatar
Okay, my dad just wants to make sure that my car doesn't over heat without us knowing it's coming. And I will use the third gauge hole in my set up for a boost gauge when I turbo the car
noob unforgiven New Member Introductions & Greetings 22 10-29-2010 07:42 PM
Another Noob CatchTheSpit New Member Introductions & Greetings 1 10-01-2009 09:31 AM
supercharger question from a noob kcfan_2004 1996-2004 Mustang GT 27 09-09-2008 12:36 AM
noob rrobello New Member Introductions & Greetings 20 01-07-2007 11:30 AM
Look, it's another noob! Low Sun New Member Introductions & Greetings 9 06-26-2006 08:07 PM
08:45 AM
