gt40 vs e7? - Mustang Evolution
Old 01-17-2011, 05:59 AM   #1
GUDNEVL's Avatar
gt40 vs e7?
i am just cirious as to what are the big dif. between the 2?could i have me e7 heads port polished new springs and done and be in the same realm of the gt40?
1989 mustang gt,short headers,3.08 gears,off road h pipe,flows,cold air intake,smog pump delete,fresh tune up,push button start,gt fog light fix ,everything else pretty much stock
most recent mod:blown head gasket
GUDNEVL is offline   Reply With Quote
Old 01-17-2011, 06:35 AM   #2
Qwik Four Six's Avatar
Not real sure but, I've got e7 's on my 89 302.
Qwik Four Six is offline   Reply With Quote
Old 01-17-2011, 11:37 AM   #3
Titus Wadicus
svtlx's Avatar
Re: gt40 vs e7?
e7 has 69cc cumbustion chambers....
gt40 & (p) have 58 or 59cc cumbustion chambers
gt40 has larger valves than gt40(p)...
gt40(p) makes more hp than regular gt40 because of increased velocity from the smaller valves. gt40(p) is a revised cobra gt40 head
gt40(p) is easier to find because it was standard head for 302 equiped mountaineer and explorer.
the bump in hp cums from the increased compression ratio of the smaller cumbustion chamber. however, you are limited to about .500 max lift with cam selection because of the smaller cumbustion chambers in the gt40 series heads.
if you wanna go larger than an e-cam (.498 lift w/1.6rr) then you need to stay with the e7's. if you arent planing on going larger than an e-cam, then go wit the gt40 series.
hope that helps.....
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 01-17-2011, 12:21 PM   #4
Not sure what cam is in my car, the guy said it was in the car when he got it also. If I post a vid could someone possibly tell me?
Old 01-17-2011, 12:52 PM   #5
Titus Wadicus
svtlx's Avatar
Re: gt40 vs e7?
i dont think anyone can tell by listening.. your best bet is to clay the pistons if you put the gt40's on to make sure u dont bend a valve. if u keep the e7's i would even worry bout it.
Old 01-17-2011, 03:23 PM   #6
Yea, not talkin bout switching heads, it'd be useful to know the cam though.
Old 01-18-2011, 06:27 AM   #7
GUDNEVL's Avatar
Re: gt40 vs e7?
most deff. helps,i am puttin in a b cam ,so i will prob just freshen up the e7's,thanks!
Old 01-18-2011, 07:09 AM   #8
Yea. Me too.
Old 01-18-2011, 10:43 AM   #9
Titus Wadicus
svtlx's Avatar
Re: gt40 vs e7?
glad all the books i read can do someone else some good....lol
WTB rebuilt gt40 heads! trickflow211 1979-1995 Mustang GT 6 03-16-2009 03:57 PM
GT40 Head bolts? mattk 1979-1995 Mustang GT 2 07-11-2007 04:56 PM
Superformance Rebuilds the Original GT40 to Specs Brent General Car Discussion 9 10-17-2006 04:27 PM
GT40 cast iron heads....... Vinnietbird 1979-1995 Mustang GT 8 10-21-2005 01:45 PM
Went & took pics of the 05 Mustang and GT40 [LARGE RES PICS INSIDE 56k BEWARE] Seph The Bar 13 11-11-2004 06:17 PM
09:40 PM
