High RPM's during emissions test - Mustang Evolution
Old 02-13-2011, 09:28 AM   #1
Just bought a supped up 1990 mustang GT 5.0. I just took it to get a state inspection and it failed. It ran 882 rpm's while idling. The max is 220. So I am way over. I just gave it a oil change and put on some magna flow cats. The only other problem I have had with it, is that it stalls repeatedly while in idle and in first and reverse. Any help would be greatly appreciated.
Ben513b is offline   Reply With Quote
Old 02-13-2011, 02:23 PM   #2
Titus Wadicus
svtlx's Avatar
Re: High RPM's during emissions test
is it an auto or manual? sound like a idle air control motor...also known as an i.a.c. really need a lil more info...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 02-13-2011, 02:41 PM   #3
It's a manual 5 speed. Do you think it might be the head gasket. Any info would be greatly appreciated.
Old 02-13-2011, 02:44 PM   #4
Titus Wadicus
svtlx's Avatar
no...i think it's the ide air control motor unless it's doin more than you told me. was the oil milky? does the car smoke? and if so, what color is the smoke?
Old 02-13-2011, 03:02 PM   #5
I'm with svtlx on this one. If that's all it's doing is idling high and not running rough or anything its most likely the IAC motor!
93CobraGuy is offline   Reply With Quote
Old 02-13-2011, 03:26 PM   #6
The engine does run a little rough and there was some smoke from the tail pipe. I would say it was a little on the black and white side. The engine is not the original, the engine in it right now has only 30000 miles right now.
Old 02-13-2011, 03:36 PM   #7
For a manual tranny it should idle at 650-720 rpm's. 220 is to low and most gas motors won't even run it that rpm, my starter on my car spins the motor faster than 220 rpm's. If the guy at the shop told you that then he lied and he his a dumb @ss.
Did the shop take and consider the mods to the motor during the test, If it smokes black that means its running rich. The little bit of white ish smoke could just be steam from the exhaust wich is normal.
Straublittleman is offline   Reply With Quote
Old 02-13-2011, 03:42 PM   #8
But should it idle at 820?
Old 02-13-2011, 03:54 PM   #9
With the motor warmed up to temp it should idle at 650-720 rpm's might as well say 700 rpm's. But if it has a big cam or anything like that it might be hard for it to do that.
rpm's for gear ratios chart Herbstang The Bar 10 06-21-2007 03:23 PM
RPM's top out at 3,000 stangracer 1979-1995 Mustang GT 11 06-02-2005 01:20 PM
Higher RPM's Due to Electrical Load? Rellik Pre-2005 V6 Mustang 11 03-30-2005 09:45 AM
Emissions Test Failed robert0803 Pre-2005 V6 Mustang 4 03-03-2005 11:08 PM
Emissions test Turkish Pre-2005 V6 Mustang 4 07-10-2004 10:36 AM
10:48 AM
