Any Ford/Lincoln Technician from the 60's era in this forum? - Mustang Evolution
Old 04-03-2011, 08:47 PM   #1
Blustreek's Avatar
Region: Hawaii
Exclamation Any Ford/Lincoln Technician from the 60's era in this forum?
Hello gang if their maybe someone with expertise on 60's model 460cid big block? The question is about a 1969 Lincoln Continental Coupe. See the problem is that it has a rough idle only @ cold start up,Then as reaches point
of normal op. temperature idle is smooth like new.Engine has no signs of leaks and is clean and immaculate stock.Everything is all original oe.Also power steering sluggish too and runs off of vacuum power assist not like today's cars.It's also non efi and has a carburetor stock.Motor was tuned up recently too.Whole car has 53 thousand plus miles on it but wasn't used in 2 decades,It was in tight dry storage all this time. Any help please asap we need it for the new Hawaii five-o show,It has a prop to do. Mahalo my fellow stangers!
<1969 LINCOLN CONTINENTAL AUTO W/460BB
53,**** MILES.>
Blustreek is offline   Reply With Quote
Old 04-03-2011, 09:02 PM   #2
Re: Any Ford/Lincoln Technician from the 60's era in this forum?
Sounds like choke adjustment is off a bit. Thats about the only thing it could be if it runs fine when warm. You'll have to look up how to adjust the choke for that carb or car. Should be simple though.
Straublittleman is offline   Reply With Quote
Old 04-03-2011, 09:04 PM   #3
aegischief's Avatar
Agree on the issue mist likely in the choke. What type if carb are you running? Holley, edlebrock?
aegischief is offline   Reply With Quote
Old 04-05-2011, 03:34 PM   #4
Blustreek's Avatar
Region: Hawaii
This car belongs to a brotherly friend of mines....The carb is stock but I think he told me that he was going to replace it with a bigger 550cfm edelbrock.
Since I'm on here lemme ask u this, What would cause a power steering system using vacuum assist operate sluggish? Low vacuum right? Or a faulty accumulator? Also the ac blows only to the floor.
Ford to discontinue Mercury, increase Lincoln lineup. OsirisGuy General Car Discussion 6 06-04-2010 09:57 PM
95 era 3.8 into a 97 with a 3.8 questions trevencath Pre-2005 V6 Mustang 5 03-14-2010 01:02 AM
Who said cars from the 60's don't last. Otlaw80 Pictures and Videos 3 07-19-2009 02:50 PM
2007 Ford and Lincoln Mercury Vehicles will be iPod Ready Brent General Car Discussion 0 10-17-2006 01:31 AM
Ford motor to make mustang based lincoln Dark02Pony General Car Discussion 7 08-03-2006 12:15 PM
11:20 AM
