89 foxbody 5.0 5spd clutch questions - Mustang Evolution
Old 04-17-2011, 06:19 PM   #1
I put a new/used transmission in my lx and now the car starts without pressing the clutch in and it didn't do it before I was just wondering if its bad for the car to do that
Jonnyfast89 is offline   Reply With Quote
Old 04-17-2011, 06:38 PM   #2
Beav's Avatar
Re: 89 foxbody 5.0 5spd clutch questions
No it is only a safety device... It doesn't hurt anything...
07 Roush 427R, Brembo 14" rotor and four piston calipers
05 GT Mustang, FRPP, FR X pipe, Hurst short throw,
American Racing Torque Thrust 10X20 wheels,
Granettelli tower brace, custom painted flat black grafix, Yellow Optima
Beav is offline   Reply With Quote
Old 04-17-2011, 07:13 PM   #3
gixxer007's Avatar
You may want to get that to work correct only to save you any chance of you leaving it in gear and causing damage to your car of hitting something in a leap forward hurry start.
gixxer007 is offline   Reply With Quote
Old 04-17-2011, 08:32 PM   #4
Beav's Avatar
It could save some grief, but it doesn't harm your car. It is probably better with it working correctly..
Old 04-18-2011, 02:08 AM   #5
I usually always disable mine so it will start without the clutch pushed in, so yeah, as said, nothing bad will happen unless you start it in gear and hit something.
93CobraGuy is offline   Reply With Quote
Old 04-18-2011, 04:28 AM   #6
gixxer007's Avatar
Is that what they do when you put remote start in a stick car? I never had a stick with remote start before only in my suto cars.
Old 04-18-2011, 07:57 AM   #7
Titus Wadicus
svtlx's Avatar
lmao... my auto starts in gear too....hahaha
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 04-19-2011, 06:38 PM   #8
gixxer007's Avatar
Wow that does not sound to good to happen in gear.
I never had much luck with remote start anyways and never end up using them to be honest.
Old 04-19-2011, 06:47 PM   #9
Knight F Mohawk's Avatar
Send a message via AIM to Knight F Mohawk
It's a good safety mechanism. The only time it's beneficial to bypass it is if you have a remote start. Fix it.
-Will
Knight F Mohawk is offline   Reply With Quote
foxbody
New Here - '88 Foxbody 1988stang New Member Introductions & Greetings 16 04-10-2011 10:02 PM
and i said i'd never own a foxbody... 04TRV6 1979-1995 Mustang GT 38 03-23-2010 10:27 AM
Please help my Foxbody Derak 1979-1995 Mustang GT 2 02-22-2009 12:46 PM
WTT 99 3.8 5spd for 5.0 Foxbody Scorpion1 Mustangs for Sale and Wanted 1 01-23-2009 02:41 PM
Poor Foxbody JROC Pictures and Videos 17 10-06-2007 03:42 PM
09:30 AM
