Bad Way To Run A Business - Mustang Evolution
Old 05-02-2011, 09:29 AM   #1
USAF_stang's Avatar
Soooo if you own a shop, someone calls and e-mails you and tells you they have the money to hand you right then all they need is an estimate on how much for the labor (and you're talking about handing them around $3k) would you
A. Get them an estimate as fast as possible
B. Ignore them for 2 weeks until you have to call and e-mail over and over again
C. E-mail them back 3 weeks later saying "Hey I have a used part I can give you for a good deal" ???
D. Both B and C
well I'd say answer A but the ppl I tried to get my cams and everything else installed buuuut I def got answer D.
can't even give money away these days
but I need a tune and suspension installed...any know anything near Columbus, GA? bc I'm done with the shops in Charlotte
USAF_stang is offline   Reply With Quote
Old 05-02-2011, 09:33 AM   #2
Loc: Austin,TX
Re: Bad Way To Run A Business
Definitely steer clear of a shop like that.Do you have a local forum that can refer you to someone?
Old 05-02-2011, 09:37 AM   #3
USAF_stang's Avatar
Thats what I don't understand...thats the place EVERYONE referred me to. Even on the forums and a few guys from NC on here mentioned it. Maybe business is just doing great for them and they can afford to be lazy.
I can install everything except my suspension kit (so I can get a 4 wheel alignment) and my rear gears....but would it be safe to drive w/o a tune for awhile? I can list everything I've got waiting to put on it if that would help
Old 05-02-2011, 09:37 AM   #4
I had to check your location because as I read it I would have sworn you were from Baton Rouge. A shop here is exactly like that. If they don't want to work on your car they either A. Ignore your request and just "forget" to reply to you...or B. Give you a price they figure you won't pay...but if you do they just laugh all the way to the bank.
Old 05-02-2011, 09:47 AM   #5
USAF_stang's Avatar
Magnaflow Off-Road Tru-X X-Pipe
Magnaflow MagnaPack Catback Exhaust
Ford Racing 3.73 Gears
Accufab 70mm Throttle Body
Accufab Plenum
UPR CAI
Ford Racing Performance and Handeling Kit
this is what I have to be installed...and wanting to get Comp Cams Stage II and valve springs installed...but no one seems to wanna do it.
would it be unsafe for my engine to drive it with the other things installed on it for awhile until I can find someone to do a tune?
Old 05-02-2011, 09:56 AM   #6
stampde's Avatar
My friend's shop is jammed , spring time's busy for performance shops , but even he has the respect to either tell you he can't fit you in or he doesn't want the job .... WTF?
2011 GT Auto
Old 05-02-2011, 10:00 AM   #7
USAF_stang's Avatar
yeah its just really bothering me....would it be that hard to install gears yourself?? I know there are certain things you have to get lined up and I'm sure my dad can help out and some of the other mechanics he's good friends with.
and I can do the suspension myself....can any place do an all wheel alignment afterwards? and would it be ok to drive a few miles after install new springs shocks and sway bars w/o it being aligned right then?
Old 05-02-2011, 10:02 AM   #8
wereKEV's Avatar
Tell that shop to go suck an egg.
wereKEV is offline   Reply With Quote
Old 05-02-2011, 10:03 AM   #9
USAF_stang's Avatar
sooo anyone know if thats a good or bad idea of doing it myself?? and I really don't wanna bring the shops name into it just bc they may be great guys and could just be bad timing or something.
Old 05-02-2011, 10:09 AM   #10
ColeJohnson's Avatar
From what I understand, installing gears is a pretty exact mechanical undertaking. Just gotta get everything in perfectly or else you can have problems. I've heard plenty of people doing it themselves, but I personally will be taking mine to a shop to get them installed.
2016 Comp Orange GT (current)
Old 05-02-2011, 10:10 AM   #11
Oh.. And do you have camber caster plates? Idk if your new suspension lowers it but if it does then you'll need those.
Old 05-02-2011, 10:11 AM   #12
Gears and cams let a shop do unless you definitely know what you're doing.
Everything else do yourself. As far as the alignment just drive the car to any mechanic shop that does alignments afterwards.
And don't worry, it's not just shops over there...
Old 05-02-2011, 10:17 AM   #13
USAF_stang's Avatar
It lowers it from the stock GT to the stock Mach1/Bullett, its a factory ford part and have been told it lowers it about 1.25 and wont need the CC plates, but thanks for the heads up anyways.
So doing the suspension should be fairly easy. I've changed shocks before...but the springs to get them in and out...how hard is that gonna be?
Old 05-02-2011, 10:21 AM   #14
Springs are easy. Just use a small jack to tension them up so you can take off the bracket.
Old 05-02-2011, 10:32 AM   #15
USAF_stang's Avatar
Cool I'll give that a try. Think my engine would be safe running w/o a tune with the other stuff installed?
Old 05-02-2011, 10:51 AM   #16
I've got aftermarket tb and intake and such on mine with an sct tuner and it runs fine.
But you'll have to wait for someone more educated on engine mechanics to chime in on this one, I'm afraid.
Old 05-02-2011, 10:53 AM   #17
USAF_stang's Avatar
surprised none of the older members on here haven't yet. They normally have made me feel stupid by now (not on purpose I'm sure haha)
Old 05-02-2011, 03:49 PM   #18
gixxer007's Avatar
Man if I ever ran my business like that I would hope someone would kick me real hard.
It funny it seem even with the economy bad and you get a customer that is going to spend money they would bend over for you. I have been seeing just the reverse I cant figure out way.
gixxer007 is offline   Reply With Quote
Old 05-02-2011, 04:35 PM   #19
Accufab Plenum
UPR CAI
Your upper list will be ok to drive around on until you get a tune, the offroad pipe will throw a code and the gears will throw off your speedo until you get a tune.
As far as actually doing the springs, the hardest part will be getting the factory springs out, the new ones will pop right in place.
Old 05-03-2011, 01:07 AM   #20
USAF_stang's Avatar
yeah I don't get it. My dad was standing there with a blank check ready to feel out the amount and he basically didn't take it seriously...its ridiculous.
cool thanks, not worried about the CEL bc it just got inspected, just don't want it to hurt my engine. and I can take it to a bud that works for Ford and get him to recal my speedo for about $20.
Old 05-03-2011, 06:46 AM   #21
Tib
Tib's Avatar
i think i'd steer clear of that shop if I was you.
2003 Roush Mustang GT Stage 2 Package - Current 'Stang
1998 Mustang GT - Previous 'Stang
Tib is offline   Reply With Quote
Old 05-03-2011, 07:29 PM   #22
MC770's Avatar
Now I've never personally been to there shop but they had a coupe of really nicely built mustangs at the autofair and seem to understand what there doing. You could shoot them an e-mail and see what they say.
Custom Performance - Services
And there's extreme mustangs in Monroe, NC that I've heard of as well but I think they mostly specialize in Fox's
~2003 Zinc Yellow Terminator Cobra~
~482 RWHP / 487 LBS Torque~
MC770 is offline   Reply With Quote
Old 05-04-2011, 09:05 AM   #23
USAF_stang's Avatar
CP are the guys I'm talking about...just didn't wanna say anything bad about their business on here.
Old 05-04-2011, 11:39 AM   #24
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Hopefully Delk's gone out of business by now but if it hasn't...don't go there (southeast Tennessee).
DarkShadow is offline   Reply With Quote
Old 05-04-2011, 12:00 PM   #25
many people who open speed shops have no clue how to RUN The business just how to work on cars so keep that in mind... they cant manage their commitments.
Old 05-04-2011, 01:18 PM   #26
MC770's Avatar
I see
Old 05-04-2011, 01:29 PM   #27
USAF_stang's Avatar
I see
yeah, I was recommended to them too from quite a few people. The whole reason my dad was getting everything done while I'm gone is bc I can't be w/o a car for more than the weekend and its easier to get it done while its not being driven. So its almost pointless to even go talk to them about doing anything when I get back.
Old 05-04-2011, 01:31 PM   #28
MC770's Avatar
Ehh worst case scenario you could rent a car while its getting worked on
Old 05-04-2011, 01:34 PM   #29
USAF_stang's Avatar
yeah but I'm also stationed in GA. Every place I've looked for near me just does Imports or its just for suspension for jacking up trucks and jeeps lol
Shifty business.... Mikes347 General Mustang Discussion 11 01-24-2011 07:25 PM
When things go bad... they really go bad for some people Brent The Bar 8 12-13-2006 09:31 PM
Dyno run goes bad! PonyTrader The Bar 15 07-25-2005 09:43 PM
Hillarys such a bad bad girl.... Brent The Bar 24 03-31-2005 04:41 PM
04:49 AM
