Brake noise - Mustang Evolution
Old 05-10-2011, 08:36 PM   #1
t0t4lbl4ck0ut's Avatar
Brake noise
It's driving me insane but there's a constant noise from one of the brakes. I can't pinpoint which one it's from either. And it seems to do it after it warms up the rotor
t0t4lbl4ck0ut is offline   Reply With Quote
Old 05-10-2011, 08:48 PM   #2
junoS197Bl08's Avatar
Re: Brake noise
What does the noise sound like?
2008 V6 Windveil Blue with 5spd standard transmission-pony package, replica rims, shorty antenna
junoS197Bl08 is offline   Reply With Quote
Old 05-10-2011, 08:53 PM   #3
Basically like brake squeal constantly. No grinding or anything like that just squeal. I've looked at the rotors calipers and pads but not to in depth. I'll be doing that tomorrow on my day off
Old 05-10-2011, 08:58 PM   #4
Send a message via Skype™ to Texastboneking
Re: Brake noise
sounds like mine. it would squeak while driving and would stop when i touched the brakes. i had an etched rotor. i machined it and if fixed the problem
Texastboneking is offline   Reply With Quote
Old 05-10-2011, 09:17 PM   #5
But mine does it even when I brake. It constantly does it. I have looked at the rears without the tires on and saw nothing out of place or any abnormal wear on the rotors or pads. The pass side did make a squeak when you would turn it at all even without the wheel. I replaced the rotor and it seemed to quite it but idk it's still doing it. Hopefully it's not a wheel bearing
Old 05-10-2011, 09:19 PM   #6
Re: Brake noise
bearings dont usually squeak. they howl or grind. might be a bad set of pads
Old 05-10-2011, 09:27 PM   #7
1ijack's Avatar
Send a message via Yahoo to 1ijack
Sounds like they forgot the shims on the pads.
The Mustang Mafia
"Join the family, if you dare"
www.themustangmafia.com
1ijack is offline   Reply With Quote
Old 05-10-2011, 09:30 PM   #8
Re: Brake noise
+1
Old 05-10-2011, 09:33 PM   #9
1ijack's Avatar
You ate doing the same thing mine are doing the same thing and they forgot the shims.
The Mustang Mafia
Old 05-10-2011, 09:50 PM   #10
Re: Brake noise
K well ill check for the shims tomorrow when im lookin at them
Old 05-11-2011, 09:32 AM   #11
wereKEV's Avatar
Re: Brake noise
there is a trab on the pads that sqweal constantly if the pads get worn too much that is what it sounds like check the pads for wear.
wereKEV is offline   Reply With Quote
Old 05-14-2011, 02:12 PM   #12
mustang0705's Avatar
Mine did that in the rear and I had plenty of pad so I greased and used a silicon on the back of the pad and it took care of the problem
mustang0705 is offline   Reply With Quote
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
Brake noise megax29 Pre-2005 V6 Mustang 1 05-07-2006 10:32 AM
weird noise.. white 98 gt 1996-2004 Mustang GT 0 12-11-2005 05:55 PM
Brake noise? SpectorV Pre-2005 V6 Mustang 1 07-08-2004 03:01 PM
07:21 AM
