I need posi - Mustang Evolution
Old 08-19-2007, 09:32 PM   #1
I need posi
I have an 86 F-250 that has a single trac diff. and I need posi. I was wondering if anyone knows what 3/4 ton trucks or vans came stock with a posi diff.?
Z-EATER is offline   Reply With Quote
Old 08-19-2007, 09:38 PM   #2
Re: I need posi
Do you know what rear your truck has now? You might come out cheaper just buying a new one rather than buying a used one and rebuild kit.
Old 08-19-2007, 09:55 PM   #3
Re: I need posi
All I know is it's dana 60 and i priced new ones based on that and there about $450 for just the diff. and $600 drum to drum. Plus I know of a junkyard that I can get it for next to nothing if I know what to get out of.
Old 08-19-2007, 10:01 PM   #4
Re: I need posi
Here ya go, I've used this site several times for information.
The Ranger Station - Tech
Old 08-26-2007, 02:08 PM   #5
fast64's Avatar
Re: I need posi
Are you sure its not a Ford 8.8?
GO BRAVES
Old 08-27-2007, 09:41 PM   #6
Scut95's Avatar
Re: I need posi
An F250 is usually a heavy duty model and they came with a stronger axle than an 8.8. Im pretty sure it came with a dana 60.
Old 08-27-2007, 09:51 PM   #7
fast64's Avatar
Re: I need posi
I think the D60 is a 1-ton axle, and the F-250 is a 3/4 ton truck, my guess is it has a D44 or a F8.8, I am gonna do some searching and see what I find.
GO BRAVES
Old 08-27-2007, 09:56 PM   #8
fast64's Avatar
Re: I need posi
According to car-part.com '86 F-250's came with an 8.8" semi-float or a 10.25" semi-float out back and a D44 up front.
If you have an 8.8" I would suggest an Aussie Locker. I have one under my Jeep and I love it. They are also cheap and easy to do it yourself: Aussie Lockers: Truck - Ford - Pick-Up (F250) - (1983 1986)
Can you get a picture of your rear axle? That would make it easy to tell.
GO BRAVES
Old 08-30-2007, 12:07 PM   #9
Re: I need posi
I'm not sure that it's a d60 but I know it's not a d44 cuz my dad had a hi-boy with a d44 and the rearend in my f-250 is alot bigger than the d44. So maybe it's a 10.25 or 8.8 like u said. I wish i could just take a pic but I don't have anyway to take it.
Old 08-30-2007, 01:33 PM   #10
fast64's Avatar
Re: I need posi
Check out this link:
Technical Video - Rebuild Your Transmission, Differential, Transfer Case
The 10.25 diff cover looks similar to a D60 cover, just w/o a drain plug.
GO BRAVES
Posi and Gear obxdude018 Pre-2005 V6 Mustang 14 07-17-2009 09:31 PM
Eaton 7.5 Posi? timpryor Pre-2005 V6 Mustang 4 04-28-2005 05:58 PM
This is posi or no?? Kiljosh Pre-2005 V6 Mustang 6 11-17-2004 08:32 PM
Posi / Tlok Donny B Pre-2005 V6 Mustang 3 12-02-2003 07:06 PM
posi rear? Mustang414 Pre-2005 V6 Mustang 4 12-01-2003 09:58 AM
06:50 PM
