Rear end strength - Mustang Evolution
Old 06-06-2011, 04:19 PM   #1
t0t4lbl4ck0ut's Avatar
Rear end strength
I wasn't sure how strong the rear end of a 02gt is. Lol I really don't want to tear something up if I don't have to
t0t4lbl4ck0ut is offline   Reply With Quote
Old 06-06-2011, 05:01 PM   #2
WildBill's Avatar
Re: Rear end strength
Strong enough for what? It's been strong enough for almost 10 years.
WildBill is offline   Reply With Quote
Old 06-06-2011, 05:24 PM   #3
Well I'm gonna be putting a kenne bell sc on it and I don't want to worry about destroying my diff or rear axel
Old 06-06-2011, 05:37 PM   #4
WildBill's Avatar
IF you don't put sticky D/R or slicks, you should be fine on the street.
Old 06-06-2011, 05:42 PM   #5
Lol had drags on it when I bought it so guess I'll just strengthen the rear
Old 06-06-2011, 05:45 PM   #6
It's got 315 nitto drags so either way I'm catching traction. Even without the drags
Old 06-06-2011, 06:10 PM   #7
WildBill's Avatar
Ford 03-04 Cobra diff and Moser 31 spline axles, weld the axle tubes and take a look at your upper and lower mounting points for your arms.
Old 06-06-2011, 06:13 PM   #8
Yea that's what I was planning on doing if I had to. My buddy was tellin me to go and convert it to the ford 9 in but that's just way to much work and money
Old 06-06-2011, 06:46 PM   #9
WildBill's Avatar
LOL..........No need for that unless you plan to race every weekend and do this several times in a weekend and expect it to last a few years!
Old 06-06-2011, 07:36 PM   #10
Yea that's what I thought too. It's mainly just a street car. Periodically I like to have some fun but not a idiots kind of fun and race every light lol
Old 06-06-2011, 10:09 PM   #11
03GT88's Avatar
If u have the funds to build your car to a level where your concerned about the rear strength you'll have enough funds to improve anything that fails
03GT88 is offline   Reply With Quote
Old 06-06-2011, 10:20 PM   #12
But that's not the point. The point is that I don't want to have to repair anything. I wanna do it right the first time not break and fix
Old 06-07-2011, 08:20 AM   #13
8.8 is a strong rear end, its all about the "shock" (instant take off) that will break it. Should last though if you dont launch on slicks.
Old 06-07-2011, 11:45 AM   #14
Just make sure you pre-load the drive line when you stage. Pre-load as in if it's an automatic ensure it's in TCC lock and your tires are just about to spin. Manuals let the clutch out while holding the brake until your car starts to bog then press the clutch in a little and that will pre-load your drive line.
254S197 is offline   Reply With Quote
Old 06-07-2011, 12:25 PM   #15
stampde's Avatar
been lucky so far with me Mach 1 / stock axles /4.10's and a T/A Cover , haven't broken it yet ,and Have probably a 100 1/4 mile runs on drag radials over the years
2011 GT Auto
Old 06-07-2011, 12:34 PM   #16
Yea the guy that onwed it before me must have been converting it to a drag car cause he put sine nitto 315 drags, 3.90 gears and finished the exhaust before he gave up on the mustang and went to a catfish "camaro". I just really don't want to be driving then have this little punk around here in a 98 cobra with just a tuner that thinks his car is a monster want to do a light run and snap my drive line or pinion or something lol
Old 06-07-2011, 12:39 PM   #17
Send a message via Skype™ to Texastboneking
My 97 cobra with a tuner will take you! Lol jk
Texastboneking is offline   Reply With Quote
Old 06-07-2011, 12:46 PM   #18
Lol he has just a plain 98 dohc cobra with a diablo tuner and he acts like it's untouchable lol I try to tell him that that car isn't anymore powerful then a stock Camaro or ta which there's tons of around here. His car looks like a toy with all the stickers and bright yellow paint
Old 06-07-2011, 12:49 PM   #19
03GT88's Avatar
I know a guy that converted a gt to a cobra. Cobra motor an everything he left the 8.8 rear. Put 31 moser. Welded the axle tubes, Detroit true trac, adjustable control arms with spherical bearings, diff cover. And he messed up the output shaft a couple of times so id upgrade that
Old 06-07-2011, 12:57 PM   #20
Yea I probably will just strengthen the entire rear cause I'm planning on cams and heads down the road. A sc is enough for a while lol
Rear End megax29 Pre-2005 V6 Mustang 8 08-27-2007 07:19 PM
95 GT rear end? IFixAircraft 1979-1995 Mustang GT 6 08-31-2006 07:07 AM
rear end v6stangracer Pre-2005 V6 Mustang 12 03-23-2005 09:41 AM
8.8 rear end KyleUSAF Pre-2005 V6 Mustang 19 11-08-2004 08:06 PM
GT rear end CajunMustang Pre-2005 V6 Mustang 2 11-04-2004 11:34 AM
06:47 AM
