Mustang lowering - Mustang Evolution
Old 08-01-2011, 11:32 AM   #1
Jesse Bach's Avatar
Mustang lowering
I got a 94 mustang gt and I got it lowerd 2inches in front and rear, I am wanting to lowering the rear another inch, but I can't find any lowering springs that are 3inches lowering, so I can I get it lowerd another inch
Jesse Bach is offline   Reply With Quote
Old 08-01-2011, 11:46 AM   #2
Re: Mustang lowering
you will probably have to cut your springs to get it any lower than 2 or 2.5 inches. Are you trying to level it out or what?
IF your springs are linear springs (coils dont get closer together at one end of the spring) cutting with a cut off wheel would be ok to do~ but its a risk no matter what .. as well as how much to cut... might have to cut a little and test etc etc
Old 08-01-2011, 11:52 AM   #3
Jesse Bach's Avatar
Yeah I'm trying to level it out the back is still up to high, they are lowering springs not coil, I'm afraid to cut them won't it ride real rough if I cut them
Old 08-01-2011, 12:06 PM   #4
well lowering springs are coil springs, thats just what a spring is so thats what I meant by using the word coil.
It may increase the spring rate which would make it ride stiffer if you cut to much off... its a risk you may have to take to find out. If you still have your factory springs you can try just cutting those slowly to get the drop you want and see how the ride is.
You can only cut ONE end of the rear springs so be SURE you do not cut the pig tail end (the end that sits on the bottom). Use a cut off wheel to cut them dont use a torch.
Old 08-01-2011, 12:09 PM   #5
Jesse Bach's Avatar
Okay thanks I appreciate it alot, I'll try it on the factory ones and see how it goes, helped alot thanks
First Mustang Country705 New Member Introductions & Greetings 28 07-22-2011 06:25 PM
I need help installing lowering springs on 94 mustang gt 94 GT 1979-1995 Mustang GT 1 07-12-2011 07:30 AM
CPO Mustang 2010 GT Premium ??? wickerman 2011-2014 Mustang GT 14 07-11-2011 10:57 PM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
08:45 AM
