How Do I Clean Out My Holes? ...spark plug holes? - Mustang Evolution
Old 08-05-2011, 08:57 PM   #1
Nel86's Avatar
As I've been tracking down an annoying tick I found something nasty under my coil packs.
I'm assuming this means the previous owner blew a plug out. Checked it no air or leaks. I just want to clean it out. Any recommendations on how?
ID:	29931   Click image for larger version
Nel86 is offline   Reply With Quote
Old 08-05-2011, 10:11 PM   #2
To avoid stuff falling into the cylinders, you'll need to pull the valve covers off to clean it out.
Definitely looks like a plug was loose for a long time in that hole.
Old 08-05-2011, 10:51 PM   #3
Re: How Do I Clean Out My Holes? ...spark plug holes?
What I always do with any COP cars is pull the coils and hit the spark plug hole with some compressed air. If you don't have a compressor just use a can of compressed air and spray a little in there to keep debris out. In order to clean any liquids you will need to pull the valve covers and clean. I'd look at replacing the O ring seals around the spark plug holes.
Old 08-05-2011, 11:00 PM   #4
Nel86's Avatar
Yep. It's sooty and caked up.
Never knew there was Oring there guess I will have to pull the valve cover.
Old 08-05-2011, 11:26 PM   #5
Passenger side come off with little resistance. Driver side you will have to remove the brake booster and work some magic. It's not impossible...just close to it.
Old 08-06-2011, 12:55 AM   #6
Jamesgt08's Avatar
Yepp work the magic good cuz it can give you some trouble. Lol
Jamesgt08 is offline   Reply With Quote
Old 08-06-2011, 03:03 AM   #7
Nel86's Avatar
any kind of solution i should use? or chemicals? I have a steamer that might help.
Old 08-06-2011, 06:57 AM   #8
stampde's Avatar
ya the passenger side VC's a ***** on DOHC MOTORS
Use some good 'ol 2+2 (carb cleaner) ,that will clean all that crap out then use some paper towels to soak up the excess and the rest will evaporate ..............
2011 GT Auto
Old 08-06-2011, 03:55 PM   #9
My passenger side came off no problem. The driver side sucked. I didn't mess with booster tho. I took off the motor mount nut and raised the driver side up an inch or so to clear the booster.
Spark plug blown out of head. 1bad2v 1996-2004 Mustang GT 17 07-03-2011 08:29 PM
09:45 PM
