And so it begins ..... - Mustang Evolution
Old 09-12-2011, 07:26 AM   #1
stampde's Avatar
Well I bought some Kooks Long tubes for my Mach back in the spring and I'm finally getting around to installing them , it took me 4 hours to get the manifolds OFF , Geez .. 1/4 turn at a time , as there isn't much room in there , still wondering how the Headers are going to fit as the manifolds barely did , wish me luck , I'll post more pics of the install as it goes down .............
ID:	31724   Click image for larger version
2011 GT Auto
Old 09-12-2011, 01:42 PM   #2
Loc: Austin,TX
Re: And so it begins .....
Nice,Kooks FTW!
Old 09-12-2011, 07:19 PM   #3
stampde's Avatar
damn , what a Bitc- this is , got the 3 tubes in on the passengers side ,one left for tomorrow ....... then the drivers side where there's more room or so it seems .......
2011 GT Auto
Old 09-16-2011, 08:48 AM   #4
stampde's Avatar
Well I had a little time last night after work and finished up the passengers side , over all not to bad , I had to jack up the engine about an inch and unbolt the A/C compressor and slide it out of the way . also had to bend the A/C lines a little to get the front tube in , not a lot of room at all ... but the line bent back into place when i buttoned up that side ,no problems ,, Sunday its on to the drivers side ... I'll post up pics when I'm through .....
2011 GT Auto
Old 09-16-2011, 10:04 AM   #5
wereKEV's Avatar
Good luck dude.
wereKEV is offline   Reply With Quote
Old 09-17-2011, 11:11 PM   #6
Dubya11's Avatar
Region: Alaska
Best of luck
Dubya11 is offline   Reply With Quote
Old 09-18-2011, 01:05 AM   #7
Easiest way is to support the engine from above and drop the K-member, gives you tons of room to play with.
Just watch the driver side header and how it's routed around the steering shaft, seen more than a few get tied up right there when installer doesn't check for clearance.
Old 09-18-2011, 02:09 AM   #8
gregtommy's Avatar
Send a message via AIM to gregtommy Send a message via Skype™ to gregtommy
good luck your over half way done on the home stretch
gregtommy is offline   Reply With Quote
Old 09-20-2011, 08:58 AM   #9
stampde's Avatar
well sunday didn't work out like i wanted to ,so its still in limbo
i need to find time to finish this up ...
2011 GT Auto
Old 09-30-2011, 09:09 AM   #10
stampde's Avatar
well the drivers side header was a BREEZE compared to the passenger side , got that finished finally , the worst thing through all this was the weather , my Garage is small ,the kind if you put a car in you have to climb out the window to get out of your car , so it seemed like every day i was off from work it rained ..........
any way my new problem was the X-Pipe i got from Kooks had different collectors than the headers , oh happy day !!!
---------- Post added at 09:09 AM ---------- Previous post was at 08:56 AM ----------
found out the headers I have are the old style ,Kooks doesnt make them anymore
they have the old style flat 3 bolt collectors ,theyre new headers have ball and socket collectors
so they made me a flat collector with a small extension of pipe , to go over the x-pipe , all i have to do is cut the beveled edge of the front of the x-pipe and slide these over and band clamp it
and being that they special made it ,they specially rammed it up my a-- with the price , LOL
2011 GT Auto
Old 09-30-2011, 10:38 AM   #11
gregtommy's Avatar
Well that's a load of crap sounds like they don't care about having repeat customers
MOTM DEC 2011
Base SC Dyno 595rwhp/493rwtrq
Refined Tune 608rwhp/504rwtrq
Mustang history started with a 2000 v6, 2003 GT, 2007 GT, 2011 GT, all Black(coincidence)
Old 09-30-2011, 10:48 AM   #12
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
thats bull *****
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 09-30-2011, 11:29 AM   #13
stampde's Avatar
na its cool , they helped me out ( i bought the headers used ) and the adapters they made for me are top notch ,stainless steel ,quality welds , etc ....
just the price was High for what it was IMO ... Post pics when I'm finished
2011 GT Auto
Old 09-30-2011, 04:47 PM   #14
gregtommy's Avatar
Sounds good looking forward to it
MOTM DEC 2011
Old 10-04-2011, 05:59 AM   #15
stampde's Avatar
here was my problem , flat collector flanges , ball and socket flanges on X-Pipe
ID:	32412   Click image for larger version
2011 GT Auto
Old 10-04-2011, 06:04 AM   #16
stampde's Avatar
beat the hell out of the ceramic coating getting them in , I did buy these used so i can't complain ...
ID:	32415   Click image for larger version
ID:	32417   Click image for larger version
2011 GT Auto
Old 10-04-2011, 06:08 AM   #17
stampde's Avatar
as you can see there was very little room to work with , in the one pic from up top you can see where i scratched the hell out of my valve cover getting the front tube in from up top ,,, don't worry I touched it up
ID:	32419   Click image for larger version
ID:	32421   Click image for larger version
2011 GT Auto
Old 10-04-2011, 06:12 AM   #18
stampde's Avatar
here's a few more , I'll post up the finished pics soon
you can see how tight the starter is in the one pic , i had to unbolt it but leave it in so i could wiggle it around to get the header tubes in , i pulled it out but couldn't get it back in after the tubes were in place, i also couldnt get the tubes in if it was bolted up , so i had to unbolt it but leave it in to do the job , geez that was a pain !!!!
ID:	32423   Click image for larger version
ID:	32425   Click image for larger version
2011 GT Auto
Old 10-04-2011, 06:18 AM   #19
stampde's Avatar
And heres the collectors Kooks sent me to adapt over my X-Pipe , i just had to cut off the ball and socket flanges from the X-Pipe and slide these over ...
this is what $160 bucks looks like
2011 GT Auto
Old 10-10-2011, 06:14 AM   #20
stampde's Avatar
and here FINALLY is the finished product !!!
ID:	32783   Click image for larger version
ID:	32785   Click image for larger version
2011 GT Auto
Old 10-10-2011, 06:16 AM   #21
stampde's Avatar
BIG IMPROVEMENT in low end torque , top end it screams !!!
and the sound is incredible , night and day difference , well worth the aggravation i went through installing them
next up a new dyno tune !!!
2011 GT Auto
Old 10-11-2011, 10:52 AM   #22
gregtommy's Avatar
Good job looks great I look forward to hearing the results of the dyno
MOTM DEC 2011
Old 10-11-2011, 12:52 PM   #23
stampde's Avatar
let you know results , hopefully i can make it out to my buddy's shop next week to get er done !!!
2011 GT Auto
10:24 AM
