Winter Storage - Mustang Evolution
Old 09-25-2011, 09:59 PM   #1
knappp's Avatar
Winter Storage
Any advice for prepping my '99 GT convertible for winter storage? Remove battery? Jack stands? Oil change? Fuel stabilizer? Etc.
knappp is offline   Reply With Quote
Old 09-25-2011, 10:59 PM   #2
Re: Winter Storage
Sounds like you pretty much have it covered.
Put the battery on a self regulated trickle charger to better preserve it.
I put mothballs under mine to keep any critters or insects away too.
Old 09-26-2011, 06:42 AM   #3
Rocco4.6's Avatar
I usually start mine ip once a month and let it run for a bit
Rocco4.6 is offline   Reply With Quote
Old 09-26-2011, 07:29 AM   #4
Re: Winter Storage
That's not really a good idea.
They never really get everything up to operating temperature and end up condensing moisture inside the engine which combines with combustion gases and produces an acidic waste that just lays in the engine for long time periods causing internal corrosion damage.
Old 09-26-2011, 09:00 AM   #5
Rocco4.6's Avatar
What is the proper way to do it
Old 09-26-2011, 09:17 AM   #6
Re: Winter Storage
I'd change the oil right before storing it to remove most of the acid forming compounds in the old oil and disconnect the battery and put it on a trickle charger.
Old 09-26-2011, 10:16 AM   #7
Rocco4.6's Avatar
Yeah but what about seals drying out from sitting soo long, i figured running it for 10 to 15 minutes would prevent that
Old 09-26-2011, 10:32 AM   #8
Re: Winter Storage
I never had any issues with seals drying out.
A good quality oil should prevent that.
It's only for a few months so I don't think you will have any problems.
Old 09-26-2011, 11:02 AM   #9
Rocco4.6's Avatar
I wanted to switch to synthetic oil but since I have never used it before I'm afraid of switching to it now
Old 09-26-2011, 11:06 AM   #10
stampde's Avatar
Re: Winter Storage
I just take mine out on a nice day for a little ride , maybe once or twice a month ,but the winter's in N.J. arent usually that bad ..........
and yes i heard just letting it idle for a while is not good ,you need to drive it
2011 GT Auto
Old 09-26-2011, 11:17 AM   #11
Re: Winter Storage
I have read that if you wait to long (no idea what too long is) to switch that the synthetics will remove the gunk around your seals and this can lead to them leaking. However I have no personal experience with that.
Old 09-26-2011, 11:40 AM   #12
Rocco4.6's Avatar
I heard something like that , I'm just staying regular never had any issues so I'll leave it be
Old 09-26-2011, 08:18 PM   #13
jwhayne0001's Avatar
Any specific trickle chargers? Same as a battery tender?
jwhayne0001 is offline   Reply With Quote
Old 09-27-2011, 04:43 AM   #14
Re: Winter Storage
The Battery Tender would be a good choice.
Any charger that will maintain your battery and not overcharge it will work.
why oh why do mustangs have to suck in the winter Justaskin00 General Car Discussion 29 10-07-2011 03:55 PM
Winter car XXSTEVEO66 General Car Discussion 3 09-26-2011 06:14 PM
Winter Storage shaqfu Pre-2005 V6 Mustang 12 09-22-2011 04:08 AM
Winter Tire & Wheel ?? Devildog1679 2011-2014 Mustang GT 10 09-06-2011 09:58 PM
WTS bmw winter wheels/tires Topless04GT The Bar 0 07-09-2011 05:42 PM
11:34 AM
