Loosing brake fluid - Mustang Evolution
Old 12-30-2011, 09:47 PM   #1
Taxman's Avatar
Loosing brake fluid
About a pint every 3 months.... I have absolutely no idea where it's going.
I have no leaks on my lines, I have searched ever inch!! I have taken my rear breaks apart to see if it was leaking in the drum an being burned off an notta.... Someone told me it can be going into my booster, is this true? If so how much will it hold? I have put almost 4 pints ( or what ever they are called the little bottles) since last year..... Anybody? Oh it's a 2006 chevy 1500 5.3 v8
Taxman is offline   Reply With Quote
Old 12-31-2011, 06:07 AM   #2
Taxman's Avatar
Anybody??
Old 12-31-2011, 06:36 AM   #3
It's not me, it's you.
primer2tone's Avatar
Have you checked your master cylinder reservoir cap? Your brake booster is not supposed to have fluid in it. If your brake master cylinder is leaking into the booster, that is a problem! The best way to check is to loosen the two nuts holding the master cylinder to the booster if it's wet behind there then your master cylinder is bad. If you replace it yourself don't forget to bench bleed the new master cylinder before you install it.
Old 12-31-2011, 04:11 PM   #4
Taxman's Avatar
I'll have to check that.....
Manual Transmission Fluid Napoleon85 2011-2014 Mustang GT 6 11-15-2011 02:47 PM
Weird brake thing that happened RVAStang05 2005-2010 Mustang GT 0 11-12-2011 06:51 AM
Has anyone solved the low brake fluid issue? Pabsny 2005-2010 Mustang GT 5 10-12-2011 09:10 PM
Most Popular Brake Pads Brent 1996-2004 Mustang GT 18 09-18-2011 10:29 AM
What Brake Fluid do you use? 99ford General Mustang Discussion 1 06-27-2011 09:34 AM
01:58 AM
