GT40p Heads - Mustang Evolution
Old 01-08-2012, 01:09 AM   #1
Region: Utah
GT40p Heads
Were there any vehicles other than the explorer that came with these heads if not, then what year of explorer do I need to find?
fairmont5.0 is offline   Reply With Quote
Old 01-08-2012, 01:33 AM   #2
93slowstang's Avatar
Just the mid 97-2001 explorers.
Old 01-08-2012, 02:10 PM   #3
Region: Utah
Alright thank you I've been wondering so that I can go out and find some for my car to put on after I do my rebuild
Old 01-08-2012, 02:25 PM   #4
No problem, if you want regular gt40 heads th 96-early 97 explorers have those. The have the standard spark plug angle so header clearance isn't a problem.
Old 01-08-2012, 02:25 PM   #5
Mile high JDF's Avatar
Someone correct me if I'm wrong, but I thought I heard that you would have header/exhaust manifold clearance issues of you put those heads on your car.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-08-2012, 02:29 PM   #6
Yes you do with the spark plugs.
Old 01-08-2012, 02:35 PM   #7
Ok, just making sure
Old 01-16-2012, 01:14 AM   #8
Region: Utah
So its smarter to go with the gt40 head instead of the gt40p
---------- Post added at 01:14 AM ---------- Previous post was at 01:14 AM ----------
Old 01-16-2012, 04:57 AM   #9
You will get the most gains out of the gt40p heads. They make headers specifically for the P heads. The gt40's are easier because of the standard spark plug angle.
Old 01-17-2012, 09:18 PM   #10
Region: Utah
Alright thanks I'm just looking for low budget horsepower gains if I had the money id just get afr's and call it good lol
Old 01-30-2012, 05:26 PM   #11
Re: GT40p Heads
Just saw this thread, I have the GT40p heads on my 351w. I had to have the head bolt holes drilled out to 1/2 inch, and I used the BBK headers. They bolt up fine and clearance isnt too much of an issue. I had to use 90 degree boots on the plugs and heat resist sleeves around the wires/boots on the drivers side only. BBK headers are much cheaper then the ones specifically for the p heads.
JPCooter is offline   Reply With Quote
Old 01-30-2012, 07:00 PM   #12
Newline's Avatar
Will the bbk headers allow the plugs to fit?
Newline is offline   Reply With Quote
Old 01-30-2012, 07:16 PM   #13
Yes but it's tight. I have to pull my driver side header off to change the #7 plug on mine.
Old 01-31-2012, 05:29 AM   #14
Re: GT40p Heads
You'll definately need to drop the driver's side header. I was easier to install 6,7,&8 plugs with the header out of the way. Youre gonna need to have 90 degree plug boots instead of straight to clear the header tubes. I also used "Cool-it" thermotec plug wire sleeves on the driver's side just to make sure the wires didnt get too close and burn on the headers. Still alot cheaper than the almost $500 for the "p" headers.
Old 02-02-2012, 12:21 AM   #15
Region: Utah
Alright good to know, but will my car still have the clearence issues if its not a mustang?
Old 02-02-2012, 06:59 AM   #16
Newline's Avatar
Yeah it's just the motor to header relationship
Old 02-02-2012, 08:49 AM   #17
stampde's Avatar
Re: GT40p Heads
ever tried using a box end wrench on that plug ??
i had those heads before but with long tubes and thats what i did to change the plugs ..... didn't have to remove them ........
2011 GT Auto
Old 02-02-2012, 01:56 PM   #18
Yeah I've tried that and cutting a spark plug socket up, there's just not quite enough room. Works for the others though.
Good Information Thread. ESG642T Pre-2005 V6 Mustang 10 01-13-2012 08:00 AM
gt40p heads Robbie94gt 1979-1995 Mustang GT 3 01-02-2012 09:28 PM
New to this...gt40p heads vs 351 Windsor.. Ponyboy66 1979-1995 Mustang GT 8 12-30-2011 10:24 PM
E7 heads or Gt40 heads? Qwik Four Six 1979-1995 Mustang GT 18 10-29-2011 09:59 PM
Cumbustion chamber size Mustang1968kr 1979-1995 Mustang GT 2 08-23-2011 11:51 AM
04:39 AM
